Page 78 of 96 FirstFirst ... 7677787980 ... LastLast
Results 771 to 780 of 960
  1. #771
    476 Post(s)
    Screws are safe mate! Just keep them torqued to spec!
    Haha yeah. It actaully had a very slow leak coming from under the screw. So I tightened it up and it stopped! Not chancing it though. I took the Patrol this morning. i must say I now know why the pivot ball can snap. Lack of lubrication. Before, the clutch pedal was light'ish, but it wasn't smooth, I could feel it grabbing, hence me thinking the bearing carrier was grabbing. Now, it feels lighter underfoot (placebo maybe), but very smooth.
    I put 29Ltrs of Diesel in it this morning, 68 F%*king dollars! The gauge needle barely moved. Lucky I have a company car and fuel card!
  2. The Following 2 Users Say Thank You to mudski For This Useful Post:
    BrazilianY60 (17th November 2022), MB (17th November 2022)
  3. #772
    Seriously thinking of ditching this Fatz Fab air box too. I should never have bought it. I should have gone the flat panel design over this. As this thing would barely do 5k in travel a year, and oiled air filters don’t like sitting around, they will lose their filtration efficiency.
    So I might look around for a better setup soon.
    Thanks to @nissannewby Brother, took his TOP advice on an A1358 panel filter for TD42 setup @mudski Brother
    Have scored out and about replacement Rycos from SC Auto/Repco/Auto One as cheap as $13.95 during Covid but the real win in my opinion is touring space saving of slimline rectangular filters stored, anywhere/everywhere, unfortunately less room for People/Picture stick mag stacks under our seats these days
  4. The Following 2 Users Say Thank You to MB For This Useful Post:
    Cremulator (17th November 2022), mudski (17th November 2022)
  5. #773
    476 Post(s)
    Where did your air box come from Mark?
  7. #774
    Beautifully engineered ‘Black Mamba’ alloy 4” airbox Mr Mark Mate. Horribly expensive twas but replacement filters are at least 1/4 price of any say GU monstrous sized cannisters
    mudski (18th November 2022)
  9. #775
    Mudski GU Build Thread
    Used to piss me off too how OEM GU & GQ filtration systems flow to a single dirty point inlet cannister/ring whatever. Their filters have alot more region to filtrate but poor design concentrates in a ‘spot’
    Much like @nissannewby Legend has always tried to educate TD42 intake plenums spreading the volume evenly. Plate type airboxes with well designed plenums too spread the load and you’ll get every pennies worth out of a cheap V8 filter
  11. #776
    476 Post(s)
    Time for a new starter battery. What model Optima Yellow top fits these GU"s?
    Hodge (9th January 2023)
  13. #777
    177 Post(s)
    I have the Bluetop D31M . Identical to yellow top except it's marine grade . But the only reason I went Bluetop it's for extra bolt posts.
    It fits, but slightly on a angle in the tray as you can see in the photo possibly.
    Sent from my Pixel 6 using Tapatalk
  14. The Following User Says Thank You to Hodge For This Useful Post:
    mudski (9th January 2023)
  15. #778
    476 Post(s)
    Thanks.
    Yeah nah I won't be buying an Optima battery after seeing the prices. Gawd.
  16. #779
    May 2016
    lower west victoria
    30 Post(s)
    Timely. I'm looking for a new aux battery.
    The CSR killed my 2nd Super Charge. Killed one on the Anne Beadell, killed the other on the CSR.
    They don't seem to like corrrrrrrruggggaaaattttiiiooonnnssss.
    Was thinking of going Optima, they have a pretty good reputation for strength & reliability don't they?
  17. #780
    Sep 2011
    adelaide
    18 Post(s)
    I run 4 D31 M batteries, just changed two in the van after 12 years . One was just starting to show signs of failing so replaced them both. Have two in the Tryhard, one start and one auxiliary both have been in there for around 8 years Only problem ,well not a problem is that the biggest you can get is 75 AH . Never had a problem, the ones in the Tryhard have covered around 200.000 Ks and alot of that has been in hard country. The van ones have been on some pretty hard country as well and would have traveled around 100.000 Ks .I wont buy anyting else. Yes they are a little on the expensive side but I`ve had good value for money. Price wise try R and J Batteries, I got the best deal around, alot better that any deals on EBay
    The Marine ones are as tough as nails, built to withstand the bashing around in boats. The M in the part number stands for Marine.
  18. The Following 2 Users Say Thank You to pearcey For This Useful Post:
    Hodge (9th January 2023), mudski (9th January 2023)
