Results 1 to 4 of 4
Thread: GU 2.8 Hoses
    May 2017
    Tumut, NSW
    GU 2.8 Hoses
    I'm after a full set of SILICON hoses - radiator and heater - for my 2.8.
    Any idea where I can get some?
    Good luck with that. Some Chinese joint off eBay if you lucky. Why Silicon?
    May 2017
    Tumut, NSW
    Silicon lasts longer and does not swell from oils etc.
    I used the standard factory rubber ones for years without issue or swelling when running a glycol coolant. When I changed to soluble oil I started to strike problems with hose sweating, however it turned out to be the coolant was the issue, so changed to a different brew and all good. I did look at silicone however someone on here raised a technical point about a negative - can't recall the comment though, but was enough to stop me going the silicone path as well.
