Page 5 of 5 FirstFirst ... 345
Results 41 to 44 of 44
Thread: GU Steering wheel audio controls install
  1. #41
    Jun 2018
    25 Post(s)
    Quote Originally Posted by 4.8man View Post
    Ok, thanks. Why do you splice the audio yellow wire to the cruise control green wire?
    Also, on the radio side of the loom you made, is that an earth open tag that needs to be connected to ground somewhere?
    From memory I spliced the audio yellow wire to the cruise control green wire as I thought the green was the cruise control earth wire, but I have a feeling that someone else has spliced it to the cruise yellow wire and it works the same, but worth testing yourself.
    Yes, that's is an earth wire on the radio side of the loom with the ring terminal that needs to be connected to an earth point.
  2. The Following User Says Thank You to Cremulator For This Useful Post:
    4.8man (16th October 2022)
  3. #42
    Beginner 4.8man's Avatar
    Feb 2011
    Brisbane Australia
    Ok, thanks. I thinks that answers all the queries I have at the moment. Now I just need to hook it up! Cheers.
  4. The Following User Says Thank You to 4.8man For This Useful Post:
    Cremulator (15th September 2022)
  5. #43
    Feb 2011
    Brisbane Australia
    Hi Cremulator, and others, I just posted my report in this section, of my finished install job. Works well. Thanks again for your help, Cheers.
  6. The Following 2 Users Say Thank You to 4.8man For This Useful Post:
    BrazilianY60 (17th October 2022), Cremulator (16th October 2022)
  7. #44
    Jun 2018
    25 Post(s)
    Nice work. I had a read of your write up, good to see you got it all working.
  8. The Following 2 Users Say Thank You to Cremulator For This Useful Post:
    4.8man (17th October 2022), BrazilianY60 (17th October 2022)
