Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 53
Thread: UPgraded CV 's and axle recommendation for GQ Patrol
  1. #41
    Patrol Guru Sprock's Avatar
    Jun 2015
    Heyfield Vic
    35 Post(s)
    I know they don’t need it but I hope all those parts come some sort of wiring loom @PeeBee - your car needs more wiring
  2. The Following 3 Users Say Thank You to Sprock For This Useful Post:
    MudRunnerTD (8th August 2022), mudski (8th August 2022), Rossco (7th August 2022)
  3. #42
    Sprocket Doodle you can be so insensitive at times. A big bloke like you should be bursting with joy, not unhappy thoughts. I will whisper some words of happiness into the breeze tonight before I go to bed and hope you will hear them.
    Probably something like ...... I think you can guess old fella, Noight noight
  4. The Following User Says Thank You to PeeBee For This Useful Post:
  5. #43
    Jun 2015
    Heyfield Vic
    35 Post(s)
    Hahahahaha just letting you know I’m still here lurking in the back ground, don’t get on here much due to work commitments but I pop in from time to time to check on things & try & catch up on the goings on.
  6. The Following User Says Thank You to Sprock For This Useful Post:
    PeeBee (8th August 2022)
  7. #44
    Picked up a set of the trail safe axle seals, noticed a slight weep from one side when last home, will give these a run instead of the genuine units
    Good deal. You'd be nuts to not run them mate. You are installing New Axles with a New hardened race for that seal. Best to run thr best seal on the new face. Double lipped. Winner.
  9. #45
    Looking at upgrading the rear axle Assy. came across a set-up for the GQ that converts the rear to fully gloating with 300m axles, looks the goods, but having trouble finding out if CEM, Custom Engineering Manufacturing are still in operation, no email or phone return calls received, has anyone come across this mob, or know of a comparable upgrade?
  10. #46
    Ok, ordered the full floater kit, 3months lead time, probably because axles ex USA
  11. #47
    There is absolutely no need for a rear axle upgrade. It's so rare for them to let go. Usually the diff centre will let go but such a rare thing for a patrol rear axle to let go. They are so big already. Your money would be better spent elsewhere. Prob a lot cheaper to source a coil H260 out of an early 3L GU. Has the bigger axles and is either semi or full floating if a remember right.
  12. The Following User Says Thank You to nissannewby For This Useful Post:
    MudRunnerTD (23rd August 2022)
  13. #48
    Thanks for your considered opinions, it's my money and if I think it's warranted and can afford it, what's the deal? I don't want the bigger pumpkin that comes with the 260 either. It's not about the cheapest option, it's about what meets the brief. Full floater in 233 footprint is what I want, and stronger to boot.
  15. #49
    Apr 2013
    Upper Ferntree Gully
    22 Post(s)
    Marks make a full floating conversion for the H233
    https://www.marks4wd.com/mfk36105.html
  16. #50
    GU only so not of interest.
