Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 53
Thread: UPgraded CV 's and axle recommendation for GQ Patrol
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    I am assuming you swapped axles as well. I understand the standard CV is 27 spline?
    If you call half-shafts "axles"...then yes.
    I bought as a set, two shafts, two CVs.
    Inner end of shafts pushes into factory diff (which I had a feeling was 31spline?) and outer end will not fit up the back of factory CVs.
    CV outer fits into standard locking hubs.
    1989 LWB 5-Seat, TD42
  2. #22
    Quote Originally Posted by mihit View Post
    Great , I have bought the monster grade stuff it seems. Dont expect to be abusing the system, however it can all be over in a split second when you lift a wheel and it comes back to earth.
  3. #23
    Goods all secured secured Phil, now which one were the stronger ones, the box on top or bottom dammit can't remember best I just take lucky dip and install one set . . . eany meanie . . .
    Glad to see Rossco, they are pretty well pointless sitting there like that, send me another shot when they are installed and I can get more of a feel if the right one is fitted. Thanks for picking them up.
  4. #24
    Nice one gents. They are both the same sets yeah? Was there a set with a higher stress rating PeeBee?
  5. #25
    Better put chromo hubs on the list as well....
  6. #26
    Gotta have a weak link somewhere though and surely the hub would have the be the easiest part to replace track side?
  7. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    PeeBee (1st August 2022), Rossco (1st August 2022)
  8. #27
    It will either be the hub or the diff centre. Easy to kill hubs with lockers and chromo axles/cvs. Genuine manual hubs aren't cheap. CVs are like anything they do wear out and don't last forever. They will fatigue as they get older and become weaker. Chromoly a lot less so and I would expect to last the life of most GQ patrols.
    You could try some of those steel strengthening rings on the hubs which would help and are quite cheap.
  9. The Following User Says Thank You to nissannewby For This Useful Post:
    rusty_nail (1st August 2022)
  10. #28
    483 Post(s)
    I blame the # taggies
    All we heard down below was #Send IT
  11. The Following User Says Thank You to MB For This Useful Post:
    MudRunnerTD (1st August 2022)
  12. #29
    I went the stronger set
  14. #30
    I run the steel rings, but curious about what constitutes a genuine hub? I bought mine new in 1997, already running free wheeling hubs - are these genuine as you call it or fitted in Australia like the aircon units? I have a spare set of hunts and also the fixed hubs supposedly ex Nissan as well. I take the point that a weak link would be nice in the drive train where it is easily replaced, but not looking to find it!
  15. The Following User Says Thank You to PeeBee For This Useful Post:
    mihit (2nd August 2022)
