Page 537 of 570 FirstFirst ... 535536537538539 ... LastLast
Results 5,361 to 5,370 of 5698
  1. #5361
    YAY nice one
  2. The Following User Says Thank You to Rossco For This Useful Post:
    Bidja (16th June 2022)
  3. #5362
    Apr 2021
    Brazil
    Fixed unit in position with Velcro for now.
    Man, I love the GU4 center dash part! What is all that stuff going on there? Can you give me a brief tour on all those gauges and modules and stuff you got there?
  4. The Following User Says Thank You to BrazilianY60 For This Useful Post:
    Rossco (17th June 2022)
  5. #5363
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    40 Post(s)
    Gadgets that sometimes put my head into a deeper state of confusion haha
    You see part of the journey, now from bottom going up:
    The radios are self explanatory.
    Just above mic is an indicator (led/alarm) for the Water Watch _ diesel/water separator. hthttps://www.waterindiesel.com.au/tp://
    Above hazard light is the Kings _ Throttle Control Unit: alters TPS signal sent to ECU/ECM (not used currently). Can work well with CRD drive by wire setup.
    Round dial gauge is used to measure vacuum @ the VNT turbo actuator diaphragm (real time) actuator rod position which indicates the VNT vane aperture opening positioning within limits set. Vac gauge also shows the change rate of the vanes aperture relative to boost pressure and MAF voltage (MAF V measures by the multi meter at top of dash). MAF voltage is taken from MAF sensor (back probe connector or as I now have spliced into ECM harness). MAF voltage correlates to MAF rate (g/s) measured.
    I play/trial with various boost control methods.
    By the way the other two (in counsel cutout), the aux/main battery monitor plus electronic brake controller for tow.
    Out of sight the (usual): EGT, Boost(relative), Oil and scan gauge.
  6. The Following 2 Users Say Thank You to Bidja For This Useful Post:
    BrazilianY60 (17th June 2022), MB (17th June 2022)
  7. #5364
    Patrol God Stropp's Avatar
    38 Post(s)
    CD45A770-11B2-4A33-8638-14DEEECE0FEA.jpeg ordered some rock sliders as I’ve bent the side steps a bit.
  8. The Following 5 Users Say Thank You to Stropp For This Useful Post:
    Bidja (17th June 2022), MB (17th June 2022), mudnut (19th June 2022), Rossco (17th June 2022), Touses (17th June 2022)
  9. #5365
    483 Post(s)
    Well Done Stroppstar, they look Strong As
    If it’s not too late are they able to infill them for you with say Checker or small hole Dimple Die plate?
    I really wish I had of taken that option on my open GU ute ones years ago.
    Have nearly Can Opened the lower sills on mine twice in ruts with sticks that pricks inlay to get height clearance through.
    Our front tyres pop them up and they spear head in between open sliders like mine and if unnoticed in time or too fast it’s a lower panel/door disaster
    Stropp (18th June 2022)
  11. #5366
    38 Post(s)
    Hi mate, I’m getting them raw and have some alloy checker plate here so will cut to suit and drill n tap a thread and put button head Allen bolts in to hold them.
  12. The Following User Says Thank You to Stropp For This Useful Post:
    MB (18th June 2022)
  13. #5367
    Expert Mickhead's Avatar
    Oct 2019
    Being a devoted Vegan/Cyclist, I unfortunately/finally ran out of crop space, shared country water too, to keep up my brain proteins growth mega hectares per 3,000m2 needed hourly ( 1 skinny man per x mega 3 hyper dramatic tarts)
    Had to sadly employ a barbaric shooter to keep the Indian Minor’s from pecking on my Foxy friends back whilst he was protecting my foreign crops from being attacked by the cutest Bunnies me and my 3 wives have ever seen
    Vegan farking cyclists 😂
  14. The Following User Says Thank You to Mickhead For This Useful Post:
    MB (18th June 2022)
  15. #5368
    483 Post(s)
    That’s the GO Stroppstar, they’ll be Excellent
  16. The Following User Says Thank You to MB For This Useful Post:
  17. #5369
    Are these a kit you assemble or come ready made?
  18. #5370
    38 Post(s)
    Message him mate, he may do a kit
  19. The Following 2 Users Say Thank You to Stropp For This Useful Post:
    MB (12th July 2022), PeeBee (19th June 2022)
