Page 12 of 29 FirstFirst ... 1011121314 ... LastLast
Results 111 to 120 of 281
Thread: General Banter
  1. #111
    84 Post(s)
    Since Andy moved us to a new serve, has anyone else copped this at all?
    It has occurred quite a few times.
  2. #112
    Feb 2011
    Shed
    45 Post(s)
    Nup.............
  3. #113
    Little Help Please Gurus
    Have been searching hard for a thread, discussion maybe to no avail
    Was along the lines of W2A (water to air) intercooler setups and my shocking memory recalls @Touses Legend with a very suitable for my hopeful upcoming needs of a rear tray/under mounted heat exchanger
  4. #114
    Patrol Freak Touses's Avatar
    Mar 2016
    Childers QLD
    22 Post(s)
    @MB Lost my pics on this puter when it crashed, will check the other, maybe there.
  5. The Following User Says Thank You to Touses For This Useful Post:
    MB (7th July 2022)
  6. #115
    Thanks Touses Mate
  7. #116
    Mar 2016
    Childers QLD
    22 Post(s)
    Found them, moved them, now will try to attach them.DSCF0171.JPGDSCF0172.JPGTA DA @MB
  8. The Following User Says Thank You to Touses For This Useful Post:
    MB (7th July 2022)
  9. #117
    Magic 🪄
    Looks like a great spot thanks heaps, are you happy with its performance back there?
    Also can’t remember what W2A intercooler you were running under the bonnet
  10. #118
    Mar 2016
    Childers QLD
    22 Post(s)
    Works like a charm, can't get the monster hot. Two 10" craig davies fans under it, coolant pushed about by 80lt? pm pump.
    Operate it via switch on dash. Pretty much don't run it cold winter mornings 'til temp climbs to comfortable heater levels.
    Ic is a frozen boost? out of the states. will find pics.
  11. The Following User Says Thank You to Touses For This Useful Post:
    MB (7th July 2022)
  12. #119
    Quote Originally Posted by Touses View Post
    What pump are you using? What are your line sizes and line pressure? Do you know what the pump draws amp wise?
    MB (8th July 2022)
  14. #120
    Mar 2016
    Childers QLD
    22 Post(s)
    Believe it's a bosch pump, no idea of amps or pressure.
    High pressure hose is 16mm id pretty sure
  15. The Following User Says Thank You to Touses For This Useful Post:
    MB (8th July 2022)
