Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Towing in low range
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    Quote Originally Posted by geoffayres View Post
    Upgrade the turbo and fit a performance pump.....and clutch....
    No more hill problems...
    ...otherwise, convert your auto hubs to manual, or fit manual hubs from a ute or DX wagon.
    … or convert it to auto trans
    John
  2. The Following User Says Thank You to jff45 For This Useful Post:
    geoffayres (6th April 2022)
  3. #12
    334 Post(s)
    If you are going to be doing this a lot then I'd be considering changing diff ratios to be honest.
    Short answer is Yes but all the reasons above re the hubs is true.
    If you have a Factory TD42T them you will be running 3.9:1 Diff ratios. Your car will be a far better tow pig running some 4.1:1 will make a difference for sure.
  4. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Rossco (7th April 2022)
  5. #13
    334 Post(s)
    Changing different ratios will also lift your cruising rpm up a couple of 100revs and your TD will thank you.
    Your TD42T HATES 2000rpm. Don't cruise at 2000rpm. Do you have a EGT Guage? If you don't you should fit as a matter of urgency.
  6. #14
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    You will only get transmission wind up if you travel in 4WD on hard surfaces AND turn corners. When you turn corners your front and rear wheels travel different distances and that is where you get lock up. If you take off from lights in a straight line there is no problem - just remember to change to 2WD as soon as you can.
  7. #15
    Quote Originally Posted by Williamsheikspare View Post
    Its a great idea to go for hill riding, And nissan has a powerful engine can bear such hilly roads
    Oi Billy Wigglestick, you don't need 25 posts for the manuals. Stop posting shit.
