Page 75 of 98 FirstFirst ... 7374757677 ... LastLast
Results 741 to 750 of 972
  1. #741
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    How much do you think it weighs with all that packed in?
    John
  2. #742
    477 Post(s)
    Nice Mudski. What awning is that mate?
    Darche Eclipse 270. So simple and fast to setup up, and pack away....
    Pretty sure the specs were 25kg. The brackets that come with it are very heavy duty.
    My only gripe with this awning is the mounting hardware. None of it is stainless steel, just zinc plated. So these will rust in no time. I'll be changing these out soon I think.
  3. The Following User Says Thank You to mudski For This Useful Post:
    MudRunnerTD (19th April 2022)
  4. #743
    Morayfield, QLD
    13 Post(s)
    I meant the whole vehicle with all that camping stuff packed in
    John
  5. #744
    477 Post(s)
    Haha! Yeah I read that in a rush, then the phone started ringing... I would guess around 3100-3200kg.
    jff45 (19th April 2022)
  7. #745
    North brissy
    Steel will last better in the long run. If you are getting out a lot then leave them steel. Stainless doesn't like to work so even with that bit off weight flexing the brackets on the highway the stainless will slowly work harden and become brittle and then just break. You can alleviate this a little by making them heavy so like 10mm thick or heavier.
  8. The Following User Says Thank You to nissannewby For This Useful Post:
    mudski (19th April 2022)
  9. #746
    477 Post(s)
    Yeah I know stainless is not as strong but having to remove rust marks from the roof with old paint is a pain. Like the roof rack I have now. I just added extra stainless bolts to replace the zinc bolts and have had no issues so far.
  10. The Following User Says Thank You to mudski For This Useful Post:
    nissannewby (19th April 2022)
  11. #747
    477 Post(s)
    What the procedure for removing the outer windscreen seal? I have water coming down the inside of the windscreen and I want to check it out. I'm hoping its not rust and just the glue is dodgy but I think it will be rust.
  12. The Following User Says Thank You to mudski For This Useful Post:
    MB (1st August 2022)
  13. #748
    483 Post(s)
    Know a Nillumbik Bloke - Mobile if you need @mudski Brother. Does most shoppies in our region
    Rossco (1st August 2022)
  15. #749
    Patrol Guru Sprock's Avatar
    Jun 2015
    Heyfield Vic
    35 Post(s)
    Hey buddy those awning pics look to be in familiar surrounds haha, like the others said it’s a weapon- genuine honest tough weapon. You don’t get vehicles like that everyday, the grass isn’t always greener my friend......
  16. The Following User Says Thank You to Sprock For This Useful Post:
  17. #750
    477 Post(s)
    Yeah I just want to remove the outer seal first to inspect it. Just not sure if theres a particular way it comes out.
    I blew my chance to score a kitted out 62 at an insanely once in a lifetime price. So unless my fortunes change, which they won't, me the the old GUrl are stuck with each other. Which I'm happy to do. Just trying to hide a stiffy when I see and hear a 62 is difficult.
  18. The Following 3 Users Say Thank You to mudski For This Useful Post:
    BrazilianY60 (2nd August 2022), Hodge (2nd August 2022), MB (2nd August 2022)
