Results 1 to 10 of 16
Thread: death wobble
    Mar 2022
    death wobble
    Hi there, I own a 2014 Nissan Patrol ex energex ute and I have had problems with the death wobble. I have had the front end done up I.E. the panard arms, bushes, bearings and everything else you can think of , plus I have had new wheels and tyres fitted by Bridgestone. I have also had the rear suspension replaced with new springs and what have you but I am still experiencing the wobble. It is very random though only happening now and then. Has anyone else had this problem and more to the point have you fixed it and how did you do it. Any help would be appreciated. Cheers
    84 Post(s)
    Check the steering damper. With one end disconnected, it should take quite a bit of effort to push it in and out. I got a Munroe one that is proving to be excellent. I fitted it with a universal rubber boot.
  3. The Following User Says Thank You to mudnut For This Useful Post:
    growler2058 (28th March 2022)
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    I was passing another Patrol on a 2 lane highway the other day at around 80-90kph when these dreaded 'death wobbles' occurred on the other vehicle right alongside me. Blood hell! If I hadn't seen it, I would not have believed just how much those wheels wobbled - it is quite spectacular!
  5. The Following 2 Users Say Thank You to Brissieboy For This Useful Post:
    mudnut (28th March 2022), Rossco (28th March 2022)
    Expert Mickhead's Avatar
    Oct 2019
    King pin bearings and radius arm bushes done?
    Check tie rod and drag link ends for play too. . Give them a quick pump of grease if this is a temporary fix then that will most likely be it. . Panhard bushes also of course. .
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Correct wheel alignment is critical. Some places just can't do it properly.
    Jul 2018
    I have had an off centre bearing installed in mine and it has driven straight ever since. True Track in Bunbury WA if you want to give them a call. I had the wobbles bad and he just laughed and said this was his bread and butter doing both trolls and cruisers with the same issue. Had new tyres since and the wear is even across the tyre so very happy
  10. #8
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    It seems that for every person to ever encounter the death wobbles there is a different fix. The most recent fix I have seen is on my friends 98 2.8 ST. After replacing every bearing and bush in the front end, trailing arms and panhard in the rear, brand new tyres on different rims, swap tyres with a mate..... he still had them. Last thing he replaced was front rotors/pads and wobbles gone. Good luck on your journey!
    Hello from Under Down Under!
  11. The Following 2 Users Say Thank You to taslucas For This Useful Post:
    AB (10th May 2022), growler2058 (9th May 2022)
  12. #9
    I replaced my wiper blades and started getting death wobbles! I blame Supercheap Auto because they had that Free fitting service and fitted them in the carpark for me... It has never been the same since that day.. I tried swapping out the Pine-tree air freshener on the mirror but that didnt even do anything!! Im going onto Facebook, the answer will be there somewhere..
  13. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    Cremulator (10th May 2022), Rossco (10th May 2022)
  14. #10
    Aug 2011
    North West Tas
    56 Post(s)
    But how good are the wiper blades?
    Sent from my XQ-AT52 using Tapatalk
  15. The Following User Says Thank You to taslucas For This Useful Post:
    MudRunnerTD (10th May 2022)
