Page 532 of 570 FirstFirst ... 530531532533534 ... LastLast
Results 5,311 to 5,320 of 5693
  1. #5311
    482 Post(s)
    What did you buy today
    Out of iso and a bit of shopping for the old girl yesterday. . Picked up an 800mm canopy some tray sides and under body boxes. . Should be bit of fun this weekend
    Fair Dinkum you don’t Muck around Rossco Legend
    A whisker late now from one work GU half podder of old to another
    Was kind of excited that you could sneak full length shovels/crowbars and the like either side of the fat new work tray for speed of ‘full length’ fast access off sides.
    Please be sure Brother to elevate your beaut new ally pod up enough off the steel tray for aeration and full length slender garden tool storage below thy pod
    Rossco (12th March 2022)
  3. #5312
    Apr 2021
    Brazil
    3 Post(s)
    Mistery box from abroad came with...
    A weatherstrip...
    And a windshield!
  4. The Following 4 Users Say Thank You to BrazilianY60 For This Useful Post:
    MB (13th March 2022), mudski (12th March 2022), Rossco (12th March 2022), Touses (14th March 2022)
  5. #5313
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    Ordered a Marks 4WD hydrobooster kit yesterday.
    Earlier in the year I did the DBA slotted rotors, new master cylinder (same as 4.8) and all stainless braided lines to go with the ECB Yellowstuff pads I already had but I was a bit underwhelmed by the result.
    I didn't want to go the bigger rotors/calipers route with bigger rims, etc
    John
  6. The Following 2 Users Say Thank You to jff45 For This Useful Post:
    Cremulator (24th March 2022), Rossco (24th March 2022)
  7. #5314
    Ballarat, Vic
    178 Post(s)
    Am amazed that you were a bit underwhelmed with the EBC pads! Did you follow their bedding in instructions to the letter? Maybe the DBA rotors are somehow less effective than the RDA Slotted & Dimpled rotors that I have with them - can't see why that should be though??? What is the hydrobooster kit?
  8. #5315
    Jun 2018
    25 Post(s)
    It's this kit using a hydraulic brake booster sourced from AC Delco in the US.
    https://www.marks4wd.com/mfk20130.html
    I just fitted this to my TD42 on the 13th March along with the braided brake lines.
    I'm taking the car away for a trip this weekend, so I'll have a chance to drive it for an extended period with it loaded up.
    First impressions after fitting it and it is noticibly different. That's with my standard rotors/pads (not sure of brand, came with the car).
  9. The Following User Says Thank You to Cremulator For This Useful Post:
    jff45 (24th March 2022)
  10. #5316
    Morayfield, QLD
    13 Post(s)
    The EBC pads were an improvement on the Bendix stuff but, with my GVM upgrade, I run permanently around the 3.2t and I just don't find the braking adequate without more than average pedal pressure applied. My 76 year old legs want the Patrol to brake like our Kia Sorento
    The "overseas manufactured" RDA are cheaper rotors than the DBA and the dimples actually do nothing in our Patrol typical usage.
    John
  11. #5317
    Ballarat, Vic
    178 Post(s)
    Yes I wouldn't say that ours (GVM upgrade 3.9t & drum brake rear - so RDA/EBC only on the front) brakes like a modern lightweight car, but the difference between this set up (including stock brake hoses) & the OEM set up is chalk & cheese. It changed the car from unsafe to safe. I don't have to use huge pressure on the pedal, but certainly more than was required in my wife's little Mitsubishi mirage which only needed a very light touch on the pedal. I did think that I might want to fit braided lines, but to be honest I think it's 'good enough'. We travel at around 5 tonnes with the Tvan hooked up & changed from Greenstuff to Yellowstuff pads only because they tolerate greater heat on long downhills without fading. Stopping performance seems about on par with the Greenstuff pads.
    I will be interested to hear your evaluation of your new setup.
  12. The Following User Says Thank You to Cuppa For This Useful Post:
  13. #5318
    Hardcore jack's Avatar
    Ballarat Area
    26 Post(s)
    I’m running the RDA/EBC all round with Yellowstuff pads, I rate the combination highly. Followed the bedding in instructions to the letter (as recommended by Cuppa). Had a good workout before Xmas when I descended the Adelaide Hills, with the fully loaded van and car being close to maxed out. Had to jump out of the heavy vehicle lane several times due to 10kph being just to slow, then had to use the brakes several times.
    Got to the traffic lights at the bottom with trepidation (after reading all the official and unofficial warnings), not a problem. Stopped flawlessly with no shudder or fade.
    Jack
    2024 Isuzu MUX
  14. The Following 2 Users Say Thank You to jack For This Useful Post:
    mudnut (24th March 2022), PeeBee (24th March 2022)
  15. #5319
    84 Post(s)
    Quote Originally Posted by jack View Post
    When towing we got stung with that Adelaide hill at the bottom, with a long traffic jam. Our set of new, but bedded in Falcon front discs warped because of the uneven heat sinking. Bugga!
  16. The Following User Says Thank You to mudnut For This Useful Post:
    jack (24th March 2022)
  17. #5320
    482 Post(s)
    Best AUD highway descent ever, compression cogging down to the city of church’s SA (kindly blows out overfueled slogging twucks after a long diesel headwind)
    SA (Port Augusta) is ……
