View Poll Results: Proactively change cylinder head gasket on high kilometre car?
Voters
2. You may not vote on this poll
  • Change it before she blows.
    1 50.00%
  • Nah, I take the chance and go with the flow.
    1 50.00%
Results 1 to 9 of 9
Thread: Should/Would you replace a cylinder head gasket on high kilometre cars?
    Feb 2022
    Cool Should/Would you replace a cylinder head gasket on high kilometre cars?
    Hi All,
    Just thinking of options on proactive maintenance for my car. Depending on your driving style and location, overheated engine is something we all dread. Doing regular maintenances does not immune you on wear and tear. So one thing came to mind is when should you consider changing the gasket on your cylinder head on high kilometre engine? Or do you wait for it to leak/crack before doing it all due to the similar labour cost?
    Thanks,
    iMan
    Apr 2021
    Brazil
    I am of the opinion that for gaskets, you don't need to replace any if they are not leaking. If you remove the head for any reason, then of course, put a new one.
  3. The Following User Says Thank You to BrazilianY60 For This Useful Post:
    Pete49 (3rd March 2022)
    Nov 2019
    Perth
    5 Post(s)
    Personally, no. I'd wait til there was a problem.
    Fit an Engine Guard for $150 and keep an eye on your engine block/head temps.
    2008 CRD Auto Wagon
  5. The Following User Says Thank You to pollenface For This Useful Post:
    84 Post(s)
    Every time you take the head off, especially alloy, you might have to get the head machined. Studs breaking, contamination, objects falling into the oil galleries, stripping threads when torquing up the head and cam gear are all risks you should avoid, just for the sake of 'might happen'.
    If you use good coolant, service the engine at the right intervals, keep the radiator clean and check the fan is working, you shouldn't have a problem.
  7. The Following User Says Thank You to mudnut For This Useful Post:
  8. #5
    Dont fix what isn't broken...
  9. The Following 3 Users Say Thank You to mudski For This Useful Post:
    BrazilianY60 (3rd March 2022), Rossco (3rd March 2022), Yeti's Beast (25th March 2022)
  10. #6
    84 Post(s)
    Good short answer.
  11. #7
    Apr 2021
    Brazil
    Quote Originally Posted by pollenface View Post
    I have bought a brazilian made digital temperature monitor device, with a bolt on thermocoupler to monitor engine temperature without depending on coolant. What would be the best place to screw in that thermocoupler, the block or the head?
  12. #8
    Good short answer.
    Seems logical.
    There's preventative maintenance and there's going that extra unnecessary bit further. Which I must admit have done once or twice.
    Rossco (4th March 2022)
  14. #9
    Nov 2019
    Perth
    5 Post(s)
    Probably the head, as that will warp first.
    2008 CRD Auto Wagon
  15. The Following User Says Thank You to pollenface For This Useful Post:
    BrazilianY60 (5th March 2022)
