Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 47
Thread: Home Heating
  1. #31
    Nov 2010
    Getting a life...
    38 Post(s)
    Hey, not sure about SA, but I pay ( when I cant get my own) Between $65 and $90 a metre, split. Quantities is hard, cos it depends on how much you use it. We run 2 coonara's ( one in shed), when I'm home I have fire redhot the whole time ( Im coldblooded)
    And we go thru about I dunno, maybe 9-10 metres a winter. We also get offcuts from the local sawmill for next to nothing.
    Hope this helps..
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  2. The Following User Says Thank You to katwoman For This Useful Post:
    rfrom7inoz (12th May 2011)
  3. #32
    WA Wheatbelt
    23 Post(s)
    I'm in a rental and have no choice but to press a button. Have a brand new chainsaw that's been used about 6 times. I help cut everybody elses.
    I take it when I go 4 x 4ing, Justin Case.
  4. #33
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Quote Originally Posted by DX grunt View Post
    your always welcome to my place 2 give your chainsaw a workout, plenty of timber 2 cut up, just don't get caught *L*
  5. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
    DX grunt (12th May 2011)
  6. #34
    Apr 2011
    South Australia
    Thx Kat. This helps a lot. I have never even had to buy wood before, so at least I get an idea of price range. Thx!
  7. The Following User Says Thank You to rfrom7inoz For This Useful Post:
    katwoman (14th May 2011)
  8. #35
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Has anyone installed one of those air ducts to shift hot air to the other side of the house.
    They look pretty simple to make but I was just wondering if they work?....no reason why they wouldn't.
    Had -7 here last night and the bedroom side of the house was freezing and the heater side was 28deg
    ________________________
    ______ 2017 D-Max _______
  9. #36
    Quote Originally Posted by NissPat View Post
    Kris, you have seen my house and I am in the same boat....
    It's only a small house and the entire house gets roasted except for our bedroom which is only 3 steps down from the house but no heat gets there....FREEZING!!!
    I have an open gable roof so there is no way to run an air duct through there as I was just thinking of this the other day.
    I am considering cutting some duct vent grills around the fire place, running the pipes under the house with a fan/duct grills mounted in the bedroom.
    I know heat rises but using the fan theoretically should suck the heat from the loungeroom.
    Has anyone done this???
    Does it work???
    I lay in bed with 2 blankets, fully clothed in the fetal position and I'm OVER IT!!!....lol
  10. #37
    ACT
    Does it work???
    Have a look at the last post on this forum....is it something you want to do?
  11. #38
    Yes, that is exactly what I want to do but not what that last post is talking about.
    He is talking about taking cold air from ground and putting it up high, etc.
    I am very temptered to put two duct vents right infront of the Coonara and run it about 7-8 metres to the lower level master bedroom and babys room.
    I've been ordered to get nice looking antique style vents if I am cutting two holes right infront of the Coonara in the loungeroom..lol
    It has to surely work...The floor boards infront of the heater are toasty hot, air is getting pulled from there down 7m to another room...Has to work!!!
  12. #39
    ACT
    I see...good luck with it mate.
    I'm gonna do mine on the weekend ...hopefully it makes a bit of difference.
  13. #40
    Any chance of a build thread, pics and report...lol
