Dont really go as far as you to validate the numbers, I just measure the panels area in square meters, multiply by 1000, then multiply by .18. So the 120 watt kings one works out to around 120 watts. Then I hook up an MPPT controller, with an cheap inline monitoring device either side. A expensive fluke dmm is placed inline, along with the fluke dc clamp. I connect it to a lithium battery that needs charging, not a near full one.In peak sunlight if the panel is not too hot I get enough amps to suggest the 120 watt claimed output is close.🤪🤪
