Page 59 of 75 FirstFirst ... 5758596061 ... LastLast
Results 581 to 590 of 747
Thread: Jay see 1997 GU build up
  1. #581
    Expert Mickhead's Avatar
    Oct 2019
    How do you validate these numbers? Solar density across Australia varies from 300 - 600w/m2 density from what I understand, and the 1000w/m2 is achieved in outer space and used as lab rating. For max efficiency I work on 600w/m2 and 16% efficiency, simply as a tolerance, as the latest NASA panels are pushing 22% but we are not able to access them, plus the panels are quickly de-rated at temps above 25 degC and the number of hours solar impact perpendicular to the panel. The MPPT controllers certainly assist with the optimisation, I just think the output is a lot less than perceived, hence why my panel area and watt output is high for the 6amp load- intermittent - from the 60L engel.
    Happy to stand corrected, but from a marketing perspective, there isn't a marketing guy out there that will sell something based on real numbers, more on the maximum possible, even if its unachievable.
    Dont really go as far as you to validate the numbers, I just measure the panels area in square meters, multiply by 1000, then multiply by .18. So the 120 watt kings one works out to around 120 watts. Then I hook up an MPPT controller, with an cheap inline monitoring device either side. A expensive fluke dmm is placed inline, along with the fluke dc clamp. I connect it to a lithium battery that needs charging, not a near full one.In peak sunlight if the panel is not too hot I get enough amps to suggest the 120 watt claimed output is close.🤪🤪
  2. The Following 2 Users Say Thank You to Mickhead For This Useful Post:
    MB (21st January 2022), PeeBee (21st January 2022)
  3. #582
    I have a slide out 100w panel under my roof rack because it’s only a 3/4 rack. The slide is simple square ally tube on each side running in ally angle slung underneath.
    It has to be pulled out to be efficient. I’ve measured 5 amps on a good day with my clamp meter.
    I don’t use a separate controller, I have the solar input on the DC/DC charger.
    Attachment 84970
    Attachment 84971
    Attachment 84972
    Attachment 84973
    Attachment 84974
    That’s definitely the GO John @jay see & John @jff45 & Ash @Cremulator Legends
    At least ya’ll can stress less with full open racks chucking long campfire logs/limbs brutally up top too with a single rope/ratchet strap enroute back to base camp for re-cutting down to pretty little sizes there that tend to end up rolling onto our bonnets every time if done prior
  4. The Following User Says Thank You to MB For This Useful Post:
    jff45 (21st January 2022)
  5. #583
    476 Post(s)
    I have a 120w panel on the top side of the roof rack. Its had everything stacked ontop of it, logs and all and still not broken.
    jay see (24th January 2022), MB (24th January 2022)
  7. #584
    Supercheap have 25% off Wednesday. I think I'll get it. I will have to check my isolator to see if it's compatible with solar.
  8. The Following 2 Users Say Thank You to jay see For This Useful Post:
    Hodge (27th January 2022), MB (24th January 2022)
  9. #585
    Bargain John Mate Be sure to grab Mudski one too….he’s much rougher than yoo
  11. #586
    476 Post(s)
    Thanks for the vote of confidence there old chap!
  12. The Following 2 Users Say Thank You to mudski For This Useful Post:
    jay see (27th January 2022), MB (26th January 2022)
  13. #587
    You’re Welcome Mr Mark Mate Legend
    There was a member here IIRC that ingeniously covered his daily rack top solar panel with an acrylic, maybe polycarbonate beautifully folded protective cover?
    My apologies, you may be rough but us Hillbillies are Fair Dinkum Pyromaniacs
    mudski (26th January 2022)
  15. #588
    Yes that was a very smart setup that one. Can't remember who though either unfortunately.
  16. The Following User Says Thank You to Plasnart For This Useful Post:
  17. #589
    177 Post(s)
    You'll love that Panel John mate. Love how the sides are powder-coated almost the colour of the roof rack so it doesn't stand out.
    I've had mine for a while. I've throw everything at it, on top of it, from swags to chunks of timber. It's been hit with a strap buckle so many times but not a scratch on it.
    But DO NOT try drilling into it like some goose I know...... See my post below. Tempered glass.
    http://www.nissanpatrol.com.au/forum...l=1#post826245
  18. The Following 3 Users Say Thank You to Hodge For This Useful Post:
    jay see (27th January 2022), MB (27th January 2022), mudski (28th January 2022)
  19. #590
    Cheers Hodge, I've just picked it up and need to pick your brain a little.
    Step 1 and 3 are straight forward, but what's step 2? The books shows it as load.
    Also I've ordered another redarc isolator sbi12d, the current one hasn't got the duel sensing. That will be just a straight swap out yeah?
