Results 1 to 10 of 11
Thread: 2002 ZD30 GU Patrol cranks but won't start. Need help please.
    Aug 2020
    Hi,
    My 2002 GU Patrol 3.0 Di used to start fine first time but today it just decided not to whatsoever.
    There's enough diesel, new battery... Just cranks, turns over but won't start. I primed the fuel filter pump, diesel flows when I removed the feed pipe. But no chance.
    Checked the fuses all ok, changed the fuel filter housing (genuine Nissan) and filter and glow plugs a year ago. Was starting fine every time. I'm quite lost...
    Can you please help me? Cheers
    477 Post(s)
    Was there any work done to the engine, or fuel system prior?
  3. The Following User Says Thank You to mudski For This Useful Post:
    gr2y61 (29th September 2021)
    Aug 2020
    Hi, no there wasn't, just attempted to start as usual.
    Aug 2020
    Hi guys,
    Problem solved so far. Used one second shot of easy start spray (Start Pilot) and it fired straight away.
    477 Post(s)
    Quote Originally Posted by gr2y61 View Post
    Hi guys,
    Strange. Being an electronic IP I was thinking toward a fubar’d pump. Tis what happened to my old ZD.
    Aug 2020
    TBH I'm the first one to be surprised but what a relief when it starts. From now on I will carry a can of that magic spray, just in case.
  8. The Following User Says Thank You to gr2y61 For This Useful Post:
    MB (30th September 2021)
  9. #7
    477 Post(s)
    Its great that you got it going, but I am stumped on why it wouldn't start in the first place. Maybe check your glow plugs to see if they are working as they should.
  10. #8
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    I've seen this happen before and it is nearly always glow plugs.
  11. The Following User Says Thank You to BillsGU For This Useful Post:
    gr2y61 (10th October 2021)
  12. #9
    Aug 2020
    Problem solved! The guilty guy was the blue 100 AMP fuse connector, located in the fuse box near the battery. The fuse is bolted and it was hard to get it out. Connected a solid copper wire to test if it will start and bingo! Just ordered 2 of those for 20 euros!
  13. #10
    Jul 2010
    Thurgoona
    7 Post(s)
    Great Result! Well done. Was it the fuse to the glow plug circuit?
