Page 513 of 570 FirstFirst ... 511512513514515 ... LastLast
Results 5,121 to 5,130 of 5698
  1. #5121
    Nic,
    big winch. Are your winch and or crumple zone mounts/airbags if fitted up to this load? My son-in-law bought an LDV and the max load capacity for his vehicle is 8000lb winch, and looking at the tin foil chassis i doubt thats even over rated. TJM make a bar but 8000lb is his limit.
  2. #5122
    Nic,
    Hi mate, the winch I have fitted is an Ironman bullbar, they say you can fit up to 12000lb for max dimensions, and I have confirmed the winch will fit in cradle. Regarding the car, my neighbour is a boilermaker welder by trade, he has said the chassis platform the car sits on is lightyears ahead of our other neighbours 2019 Hilux, infact he went as far as to say it it is probably one of the best welded, and strongly constructed chassis' he has seen in the modern vehicle market. His bread and butter is he works on busses, trucks and light vehicles so I'll take his word for it.
    To be fair I highly doubt I'll ever be loading the winch up that much as much as it's capacity, it was just a decent price, from a Victorian company(not king's) and I figured what can I loose.
    Do you see any problems I hadn't considered?
  3. #5123
    Its a fair thing to suggest you won't use the capacity until you do. In the engineering field, you design the structure to suit the max load the winch can develop, and then whatever factor of safety. Look up some load recovery factors for bogged to the floor board vehicles, and see how the load magnifies. Ultimately your call at the end of the day, just don't let the recovery ops get away from the stated capacity of the bar - yes, your words say 12000lb max dimension, but ultimately you have a beast that supposedly can generate 17500lbs single line pull. If you do pull the chassis out of alignment or something lets go on the winch bar or mounts, could be an interesting conversation with the insurance company at best. If it was me, I would be guided by the capacity of the bar, rather than the assurances of the boilermaker next door.
  4. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    Cremulator (12th August 2021), rusty_nail (12th August 2021)
  5. #5124
    fair call mate. i guess im never going to put this car into the position it will be bogged, or winching two vehicles out in situ, at max load ill be pulling over a tree in my yard, clearing a track or pulling the car loaded with firewood up a hill thats too slippery to drive. ill keep in mind your comments.
  6. The Following User Says Thank You to rusty_nail For This Useful Post:
    PeeBee (12th August 2021)
  7. #5125
    SUCH IS LIFE Maxhead's Avatar
    ACT
    What did you buy today
    A lot of engineering says this and that, at the end of the day bigger whinch will do a better job. Who gives a fuck. Drive it, get it stuck and winch it. Get out…happy days
    ________________________
    ______ 2017 D-Max _______
  8. The Following 3 Users Say Thank You to Maxhead For This Useful Post:
    Hodge (13th August 2021), Rossco (13th August 2021), rusty_nail (13th August 2021)
  9. #5126
    Maybe you could do us all a favour and start an auto 4wd insurance company with these terms and conditions - I suspect you would get a lot of policy's and equally a lot of claims.
  10. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    Hodge (13th August 2021), Maxhead (13th August 2021)
  11. #5127
    177 Post(s)
    I'll take out a policy for sure .
  12. The Following 2 Users Say Thank You to Hodge For This Useful Post:
    PeeBee (13th August 2021), Rossco (13th August 2021)
  13. #5128
    ACT
    Insurance? Why complicate things
  14. #5129
    Hey mate was thinking seriously today about your suggestion, just wondering, if you are doing a double line pull does this not also increase the pulling capacity of the winch or the force the winch is able to pull through? Does that mean if you winch out with a double line pull you would also be exceeding your bullbar capacity? Keen to hear it from an engineering perspective
  15. The Following User Says Thank You to rusty_nail For This Useful Post:
  16. #5130
    177 Post(s)
    You'd be halving the load and splitting it between the bar and whatever the hook ends up being on.
    Usually the recovery point which is usually on the chassis.
  17. The Following User Says Thank You to Hodge For This Useful Post:
