Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: New winch needed or not??
    My winch has developed a fault. It sometimes works and sometimes not. When it's not working I can hear the solenoid clicking, but that's it nothing is moving.
    Should I take it out, open the electrical side and clean all the contacts before refitting or buy a new bare unit.
    I've recently brought new quality rope and hook, it also runs an Albright solenoid. The winch is a old t-max.
    Suggestions please...
  2. The Following User Says Thank You to jay see For This Useful Post:
    MB (13th July 2021)
    Check that all the connections to the motor itself are clean and tight. If they are, remove the motor and see if it runs off the winch. Quite possible the motor is cactus.
  4. The Following 2 Users Say Thank You to mudski For This Useful Post:
    jay see (13th July 2021), MB (13th July 2021)
    483 Post(s)
    What Mark Mate kindly said above would be my first point of quick high load/earth connections check too John Mate
    FWIW: Our winches/wiring are certainly out front coping the full brunt of all crud on tracks and later parked up in the stagnant elements for additional potential connection corrosion too
    Dielectric grease I use on my winches connections after scrub downs although I believe @PeeBee has an ever better protection’Aluminium’ based goo I think maybe?
    EDIT: …..after ‘terminals’ remove/reinstall “scrub downs” in between…..not slapping over the top
  7. #4
    I use Aliminox D-ALM325G. Its a high performance conductor and inhibits joint corrosion by keeping the moisture/air out at the interface of the surfaces. Its designed for compression joints, not simply a slap on over the top to keep the liquid out. I have the 325g tube, which will do a heap of joints. Its distributed by Performance Line Products, 02 8805 0000, 190 Power street Glendenning NSW 2741
  8. The Following 3 Users Say Thank You to PeeBee For This Useful Post:
    jay see (13th July 2021), MB (13th July 2021), mudski (13th July 2021)
  9. #5
    483 Post(s)
    Well Done Philstar Legend Mate
    FWIW: In theory John Mate, you could also test your winch motor +/- windings by way of old school jumper cables wherever Sheep Yards may be
  11. #6
    Cheers gents.
    I did give it a bit of a feel around the cables and they seemed ok, but I will undo, clean and refit them.
    I have no idea how old it is, but I'm guessing at least 10 years, if its time for a new one what are the recommendation/requirements.
    Ironman
    Mean mother
    Ridge Ryder
    Runva
    SPECIFICATIONS
    Minimum 9500 lb ???
    Motor kw/hp ???
    I see the warranty is varying from some having 1 year electrical warranty and limited 3 year on mechanical and others have 5 year electrical, limited lifetime mechanical, but this based on price.
    Is anyone using any of the above mentioned?
  12. #7
    84 Post(s)
    If you have to get a new winch, make sure it has a warranty that isn't made void due to the unit being submerged. Also check that the first stage gearing is made of steel, not cast as part of the aluminium case. The Braking system needs to be more substantial than the one Aldi and some other winches use. You also need to check that the anchor point for the rope is better than just a small bolt holding a crimped lug.
  13. The Following 2 Users Say Thank You to mudnut For This Useful Post:
  14. #8
    483 Post(s)
    Runva seems to get a lot of votes here and elsewhere as a very fair deal, bang for buck John Mate. Cold water ingress betterer heat/sealed I believe owners swear by from reading only and priced reasonably for above budget yet near gnarlier needs potential IIRC ?
  15. The Following User Says Thank You to MB For This Useful Post:
  16. #9
    Thoughts on this, about $300 less compared to a complete one.
    https://www.toughtoys.com.au/product...re11xpprem12v/
  17. The Following 2 Users Say Thank You to jay see For This Useful Post:
    Hodge (13th July 2021), mudnut (13th July 2021)
  18. #10
    177 Post(s)
    Runva all the way.
    Stay away from Carbon is all I will recommend.
  19. The Following User Says Thank You to Hodge For This Useful Post:
