Results 1 to 10 of 16
Thread: Gq backfiring
    Sep 2020
    Gq backfiring
    Hello,
    Just recently got my tb42e started and it is running like an absolute dog, backfires out of exhaust and intake and won’t rev up.
    Would anybody have any ideas?cheers
    84 Post(s)
    There are a few causes. Is it dual fuel? Leaking injectors can also cause it.
    Sep 2020
    Straight petrol and brand new injectors
    483 Post(s)
    Could the timing belt have possibly skipped over a cog or two and or stretched, not sure if that’s possible?
    Expert billyj's Avatar
    gordon
    3 Post(s)
    fuel pump is stuffed
    gone to the dark side 2017 vdj 79 dc
  6. #6
    Airflow meter,when I had my VL commonwhore it was the biggest problem with 5hat motor
  7. #7
    Expert Arfa Brayne's Avatar
    Jul 2016
    Crossed plug leads - check your firing order.
  8. The Following User Says Thank You to Arfa Brayne For This Useful Post:
    MB (8th June 2021)
  9. #8
    483 Post(s)
    Now that makes perfect sense to nuffy me AB Mate, ping pong, would explain the valves open exploding with inwards & outwards ignition after TDC/BDC if that’s correct?
    Arfa Brayne (10th June 2021)
  11. #9
    Sep 2020
    Brand new pump mate
  12. #10
    Quote Originally Posted by PatrolOwner69 View Post
    Brand new pump mate
    Does it idle ok,and only backfire when revd up
