Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Small Part needed - can you help?
    Patrol Guru paulyg's Avatar
    Ballarat
    I had a similar problem with my winch, I just removed the plug and made it wireless, with a cheap ebay kit, works great.
    2010 TB4.8, 5 speed auto TI Wagon, Beaudesert ceramic coated Extractors and 2 1/2 inch exhaust, 3inch lift, BP-51 shocks, Black hawk radius arms and drop boxes, Road Runner Offroad billet alloy draglink, Boss air bags, 295/70/17 KM3s, Redarc Gauges, GME XRS UHF, Autometre fuel gauge, Alpine head unit with offroad maps, Carbon winch, Opposite lock bull bar, Light Force Strikers, Safari Snorkel, Duel long range tanks, work in progress.
  2. The Following User Says Thank You to paulyg For This Useful Post:
    Cuppa (15th May 2021)
  3. #12
    176 Post(s)
    Fixed with thanks to @Plasnart & the forum. Getting the control box out was a total bastard, the hole in the bull bar is pretty much the same as the top of the control box BUT the four sides of the control box taper out toward the bottom. Ingenuity, brute force & persistence paid off though. A few sparks alerted me to the need to disconnect the battery! Tested the winch after job was complete with crossed fingers. All good. Phew!
    Supplementary Question The control box clearly isn't watertight. How come things don't go pear shaped when I drive through water?
  4. The Following 5 Users Say Thank You to Cuppa For This Useful Post:
    Hodge (19th May 2021), mudski (19th May 2021), Rossco (20th May 2021), rusty_nail (19th May 2021), threedogs (22nd May 2021)
  5. #13
    176 Post(s)
    Any comments on the 'supplementary question'?
  6. #14
    198 Post(s)
    The solenoids are a crimp fit assy, so will take a mild dunking, but if you submerge them for an extended period, say 30 mins (as has happened to me when I had a Warn High Mount, they seep water and thats the end of them. You can add a bit of protection with silastic, but thats about it
  7. #15
    84 Post(s)
    Cuppa, I have used a proper waterproof electrical Junction box mounted near the passenger side firewall. It means longer leads, but negates any sort of damage by a front end collision, too.
  8. #16
    176 Post(s)
    Thanks Peebee & Mudnut. Have been through plenty of water crossings without a problem. When I found the box was unsealed yesterday, & I inadvertantly earthed something & got some momentary sparks I wondered why water would not complete a circuit, potentially operating the winch (it obviously doesn't or I would have discovered that by now) - or indeed if ever needing to winch out of water whether the water in the control box would prevent use of the winch.
    If I ever remove the cover again I'll use silastic when re-fitting it.
  9. #17
    198 Post(s)
    Sorry Cuppa, I am referring to the solenoid cans only. You could pour 1kg of silastic into the big plastic box and still not seal it! If you are looking for a better system, go the solid state sealed units. There are a range of different chinese knock offs and some more expensive un its for higher duty points and maybe quality.
  10. The Following User Says Thank You to PeeBee For This Useful Post:
    Cuppa (20th May 2021)
  11. #18
    UK- Albright Sealed Gents
    https://www.the4wdshed.com/albright-solenoid-12v
    https://www.roadrunneroffroad.com.au...lenoid-12v-sup
    Competition Proven and FWIW out front they do handle the elements just fine, in fact, the closer they are wired to your winch motor the least amount of amperage drop the better.......mythbusted by our member mate on his and mine @matfew (Industrial Sparky)
  12. The Following 2 Users Say Thank You to MB For This Useful Post:
    Cuppa (22nd May 2021), rusty_nail (22nd May 2021)
  13. #19
    FWIW: The sole reason 4WD Action TV took 3 days to pass through Tasmania’s ‘Thousand Dollar Twack’ was inferior winches
    3 x Patrols smashed it in 6 hours with bulletproof Albright’s out front
  14. The Following 4 Users Say Thank You to MB For This Useful Post:
    Avo (22nd May 2021), PeeBee (22nd May 2021), rusty_nail (22nd May 2021), threedogs (22nd May 2021)
