Results 11 to 20 of 22
Thread: Why use a hook when winching??
    My recovery doodads, the 50 ton strap is in case I have to recover a Road Train or Mine Haulpak
  2. The Following 3 Users Say Thank You to the evil twin For This Useful Post:
    Bigcol (31st December 2017), MB (29th December 2017), PeeBee (29th December 2017)
  3. #12
    198 Post(s)
    Thanks ET, I think I will have to set one of these up to really understand the failsafe. Is there a purple strap doubled on itself thru the eye of the two straps to the vehicle and then thru the ey of the tow strap? How are the thin blue tethers secured to the straps - simply tied?
  4. #13
    Hiya Cobber,
    There aren't two straps to the vehicle, it is a standard equaliser bridle setup
    The anti-recoil tethers are sewn onto the respective bridle or snatch strap approx 1 metre back from the rolled eye.
    The 'purple' on the equaliser bridle is a protective sleeve that you can slide to the appropriate point.
    Setup is simple, you just attach the anti-recoil strap eyes to a separate point from the 'snatch' anchor point/s.
    I use soft shackles preferably.
    If the anti-recoil strap isn't long enough for some reason you can use rope or a sling or whatever to lengthen
    Takes all of 30 seconds and no need to rrse around with dampers
  5. #14
    198 Post(s)
    Hiya Cobber,
    Thanks for that, where do I buy one or search for bridle strap?
  6. #15
    Here’s ET’s advice to all from a keyword search here mate: The link doesn’t appear to be working in the old thread anymore but Google has found it again, Cheers ET! http://www.comsew.com.au/products/4x4-recover-kit/
  7. #16
    198 Post(s)
    Thanks Mark, found them on ebay a moment ago.
  8. #17
    Apr 2021
    Brazil
    3 Post(s)
    If you have a moused hook then don't use a shackle just put the strap loops into the hook.
    If you have a hook that is attached by a clevis pin or otherwise to the winch line then take the hook off, stow it somewhere and use the eye, you will find you will use the eye more often than the hook anyway.
    If you use the hook beware you don't tip load it IE make sure the load is inline with the winch cable pull.
    If you use shackles then use D for Chain and Bow for Straps
    If you attach your winch line to the shackle pin then you may want to pack the shackle pin so the line is centered esp if it is a metal thimble
    A lot of unknown vocabulary here for me. Can someone help me understand these?
    "If you have a moused hook..." What type of hook is that?
    "If you have a hook that is attached by a clevis pin..." I kind of think I know this one, but I'd rather confirm... Is this that pin that is locked by an aluminium wire similar to castle nuts locking pin?
    "If you use shackles then use D for Chain and Bow for Straps" This one I am completely lost.
    "If you attach your winch line to the shackle pin then you may want to pack the shackle pin so the line is centered esp if it is a metal thimble" What does he means with pack the shackle pin?
    Thanks!
  9. The Following User Says Thank You to BrazilianY60 For This Useful Post:
    Cremulator (14th May 2021)
  10. #18
    476 Post(s)
    Thanks!
    Your lucky that @MB ; didn’t try to explain it then. Lol. We’d all be confused. Haha!
  11. The Following 4 Users Say Thank You to mudski For This Useful Post:
    BrazilianY60 (15th May 2021), Cremulator (14th May 2021), MB (5th June 2022), MudRunnerTD (14th May 2021)
  12. #19
    176 Post(s)
    Your lucky that MB didn’t try to explain it then. Lol. We’d all be confused. Haha!
    Lol.
    There is still time for that. @MB please translate the above for the fella. Thanks.
  13. The Following 4 Users Say Thank You to Hodge For This Useful Post:
    BrazilianY60 (15th May 2021), MB (5th June 2022), MudRunnerTD (14th May 2021), mudski (14th May 2021)
  14. #20
    Jun 2022
    Interesting
