Results 1 to 5 of 5
Thread: 1980 SD33 Thermostat housing
    Mar 2021
    Hi All, Just got myself an MQ SD33. I managed some time over the weekend to start looking into her problems and started with the cooling system. Does anyone know where I might get a thermostat housing (top and bottom) as the top is corroded away and the top has been glued down due to a stripped bolt. I have not been able to find one on the net so far.
    Wreckers would be your only option I would say. Good luck
    11060C6801 is the part number for the top housing, 21202T3470 is the part number for the lower section. Maybe try a Nissan dealer and see if they can get them, even from Japan maybe.
    Mar 2021
    Thanks mudski. I thought that might be the case.
    Mar 2021
    Just spoke to Nissan, and you wouldn't believe it. The top housing is in melbourne and the bottom is available from Japan aparently. The cost for the top half is expensive but the bottom half is almost three time the top. Ouch. Will look at the wreckers and see what I get. Thanks again to mudski the numbers are spot on.
    No problem.
