Page 994 of 1057 FirstFirst ... 992993994995996 ... LastLast
Results 9,931 to 9,940 of 10565
  1. #9931
    476 Post(s)
    Thanks, Mudski, but I can't take credit for this. The engine builder thought of it, I just swapped out the components.
    Your pretty clued up mate. Don’t right yourself off that easy. You pipe up pretty quick if someone asks about these motors.
  2. The Following 2 Users Say Thank You to mudski For This Useful Post:
    MB (16th February 2021), mudnut (16th February 2021)
  3. #9932
    84 Post(s)
    They have so many quirks and so much potential, they're worth studying. I've been researching to build one with an RB34 stroker kit with NA pistons for a bit of low down grunt, giving a bit more flexibility. It would hammer but look stock.
  4. The Following 4 Users Say Thank You to mudnut For This Useful Post:
    10G (17th February 2021), jay see (19th February 2021), MB (17th February 2021), mudski (17th February 2021)
  5. #9933
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    Put half a shed junk checker plate box to use as a heat shield from the pissy little Safari turbo:
    Shouldn't a heat shield like this be light coloured (absorbs less radiated heat than dark) and glossy (reflect more heat than matte finish)?
  6. The Following User Says Thank You to Brissieboy For This Useful Post:
  7. #9934
    A great point thanks BB Mate
    Pretty sure that without light colour doesn’t exist though hopefully it’s dark enough under the bonnet
  8. #9935
    Thanks heaps again for kindly bringing this to my attention @Brissieboy Mate!
    You’ve thankfully got my arse into gear searching for a best heat insulation stick on stuff for the shed junk steel box contraption.
    Only needing a small square piece for the turbo front radiant face I’m hoping will assist when the ute returns from suspension work and can only shop collect find so far this SCA one tonight:
    https://www.supercheapauto.com.au/p/...PO7481130.html
    Has anybody used the SCA stuff before or could kindly recommend any other options that can be purchased around 300x300mm instead of an entire firewall sized roll ?
  9. #9936
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    How about just a thin piece of polished stainless or similar. Pretty sure any mirror-like finish should prove effective as a shield based on my old school physics where we delved into the workings of the vacuum thermos flask which uses such surfaces. Of course the vacuum gap would help as well but that may be just a tad more difficult to achieve, but a small air gap might help as well if it is mostly radiated heat causing the problem.
    What you need to achieve is minimum absorption on the outside and minimum radiation from the inside. And even better if you can get a little cooling air flow on the inside.
  10. The Following User Says Thank You to Brissieboy For This Useful Post:
    MB (19th February 2021)
  11. #9937
    May 2016
    lower west victoria
    30 Post(s)
    I put a piece of bent ally chequer plate on the outside of my 2nd battery holder. Only had 1 90 degree bent bit, so I left about a 10mm gap between the end of the holder and plate up where the turbo is. Don't know if makes any diff, but it's something.
    Black ally, or ally coated black, is used to suck heat out of stuff when attached to the stuff and silver to repel the heat.
  12. The Following User Says Thank You to 10G For This Useful Post:
  13. #9938
    Awesome ideas thankyou Gentlemen, Appreciated
    Think I get exactly what you mean and reckon I’ll have something floating around the shed to bolt on with a 10mm gap in front
  14. #9939
    May 2016
    lower west victoria
    30 Post(s)
    bigger the gap the better, I only had about that much to play with.
  15. The Following User Says Thank You to 10G For This Useful Post:
  16. #9940
    WA Wheatbelt
    23 Post(s)
    @Lights
    Got my 2 x 40" Extreme series light bars working, but they need a bigger fuse (doh!)001.JPG
    Used during day time coz I'm scared of my own shadow. LOl.
    Can't wait to get the fuse replaced and I'll pass on a couple of night time shots.
  17. The Following 5 Users Say Thank You to DX grunt For This Useful Post:
    10G (21st February 2021), Lights (24th May 2021), MB (19th February 2021), mudnut (20th February 2021), mudski (19th February 2021)
