Results 1 to 10 of 12
Thread: 3.0 DDTI injector service gotchas
    Nov 2019
    Northern Beaches
    3 Post(s)
    Angry 3.0 DDTI injector service gotchas
    It's a 2008 3.0 with CRD
    Been thinking about taking out the fuel injectors and then having them taken to a shop to get them serviced.
    I am allways on a budget.
    I am searching on them internets on my own, but I thought I'd cast here too, there's allways some gems I pick up here along the way.
    So the question is:
    Can I replace the diesel injector nozzles on my own? Without any specialised tools?
    And then, I gues this is related to the above paragraph, the manual says that whenever the high pressure fuel line gets undone from the top of the injector, it should be replaced with a new piece. But that kinda seems far fedged, no? I mean it's a steel fitting no? I am thinking there is likely just a little o-ring sitting inside that needs to be replaced, but surely not the whole pipe...?
    476 Post(s)
    You can't service the injectors, they are a sealed non servicable part. You can remove and refit by yourself. Replace the seals while your at it. You should replace the injector pipes as the manual says because you will have around 30,000psi of fuel pressure through them and if you could damage a pipe or connection without knowing. There's no oring in them too.
  3. The Following User Says Thank You to mudski For This Useful Post:
    growler2058 (8th February 2021)
    Feb 2011
    Shed
    45 Post(s)
    Quote Originally Posted by poddy View Post
    So the question is:
    Keen to learn more about this too. I heard its $4500-$5000 to get injectors replaced. Waaaaaay exxy!!!
    476 Post(s)
    if you can use a spanner, you can replace them. Not hard, just time consuming.
    Feb 2011
    Shed
    45 Post(s)
    I was more worried about the 30,000 psi taking me out
    476 Post(s)
    Pressure in those lines is gone soon after shut down.
    growler2058 (9th February 2021)
  9. #7
    Nov 2019
    Northern Beaches
    3 Post(s)
    So is it not a thing anymore? Like, back in the good old days, I was able to remove the injectors off the engine, take them to a shop where they plugged them into their ultra-sound machine, run some special cleaner through them at high pressure (I'm guessing?), and checked for spray pattern and what-not.
    Is that it? The only possibility is to replace the injector? End of story?
  10. #8
    Nov 2019
    Northern Beaches
    3 Post(s)
    I believe it can easily be that high.
    If you pay someone else to do it for you (like a service centre)
    If you use the genuine Nissan set of injectors (cheapest genuine Nissan part I found was around $650/pop) $$$ (But the bosch part of e-bay goes for around $320/pop and they are allegedly made in Japan...)
    If you replace the whole system, including the common rail, high pressure diesel pipes, low pressure diesel hoses. (The genuine common rail itself is around $0.9k, plus the high pressure pipes are $50-$100 depending on which one)
    And if you want to replace the diesel pump with a genuine Nissan part too, you're well over $5k - no questions asked.
    With that said, there is an alternative route:
    You do the work yourself.
    You use the cheaper bosch parts off ebay.
    You have the diesel pump rebuilt instead of buying a new one.
  11. The Following User Says Thank You to poddy For This Useful Post:
    growler2058 (26th March 2021)
  12. #9
    Nov 2019
    Northern Beaches
    3 Post(s)
    I see what you're saying; What if I was to use a copper washer that fits and torque them high pressure lines to spec, that should do the trick, no?
  13. #10
    476 Post(s)
    Too hard to explain why without showing what the end on the tubes look like under the nut, but no.
