Results 1 to 10 of 19
Thread: When to drain oil??
    May 2016
    lower west victoria
    30 Post(s)
    When to drain oil??
    I've thought it's best to drain your oil in the morning after your vehicle has been sitting all night and every last bit of oil that is going to end up in the sump should be there.
    But there's also the train of thought that you should drain your oil when it's warmed up / hot so it all drains out as it's thinner at that time.
    What do you guys think?
    84 Post(s)
    Depends on how much time you have. In the morning, all the oil that will drain away has done so just after the engine shut down. The length of time that the oil drains out cold is extended. If it is at operating temp, the oil will flow quicker, but there is still oil to be drained from the rest of the engine.
  3. The Following User Says Thank You to mudnut For This Useful Post:
    10G (6th February 2021)
    476 Post(s)
    Best when the oil is still warm as its at its thinnest so more will drain out. I usually would drain mine around half hour after the engine has been running and at running temp.
    May 2016
    lower west victoria
    30 Post(s)
    Thanks guys.
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    Old school theory was that it is best to drain while hot and immediately after a good run. That way all the crud is mixed up in the oil so drains away instead of settling on the floor of the sump just waiting for the new oil.
    Not sure about about more draining out when hot because of the action of multigrade oils that thicken with temperature. Would have been true in the old days before multigrade.
  8. The Following User Says Thank You to Brissieboy For This Useful Post:
  9. #6
    May 2016
    lower west victoria
    30 Post(s)
    That's something I hadn't considered, the draining of the crud, I'm sure you'd get more crud out when hot. Thanks Brissieboy.
  10. #7
    Nov 2019
    Perth
    5 Post(s)
    Always change it hot.
    2008 CRD Auto Wagon
  11. #8
    Expert jman69's Avatar
    S.A.
    I always drain mine after it's been driven for a while, so it's nice and hot. Then i let it drain over night to get as much of it out as i can, refilling in the morning.
  12. The Following User Says Thank You to jman69 For This Useful Post:
    mudnut (6th February 2021)
  13. #9
    Feb 2021
    You might not want let it drain to long, could empty The oil pump and create extra wear on start up, the filter is what gets rid of any thing that’s not oil and the oil will always be black that’s just old school Diesel engines
  14. #10
    Ballarat, Vic
    176 Post(s)
    Drain when hot 'cos I just love the extra challenge of getting into the difficult to reach filters when they are hot, & nothing better than getting hot oil splashed on me when cracking open the sump plug!
    Nope
    But I do drain it hot for all the reasons others have given.
  15. The Following User Says Thank You to Cuppa For This Useful Post:
    Rossco (9th February 2021)
