Page 60 of 64 FirstFirst ... 5859606162 ... LastLast
Results 591 to 600 of 635
Thread: Rosscos GQ Rejuvenation
  1. #591
    Rolling around under the GQ sussing out the exhaust with potential to reroute and hug the chassis with plans of a custom stainless water tank on LHS of shaft. . . Anyways spotted a coolant leak coming from oil filter / oil cooler area. . Will need to get onto this, is this most likely simply gasket or something more complex / sinister. Not sure whether to tackle myself or take into shop pretty busy ATM as always lol. . Also need to get into oil leak from breather that is making a mess everywhere. .
  2. The Following User Says Thank You to Rossco For This Useful Post:
    MB (29th January 2021)
  3. #592
    483 Post(s)
    Get onto a shop and beg ASAP if too busy yourself Rossco Mate!
    Incredible how long lead times appear to be over the last few months since lockdown release on all things mechanical & off-road etc...
    Can we find some quick time this weekend to hills pressure test the coolant system for starters squirts maybe?
  4. The Following User Says Thank You to MB For This Useful Post:
    Rossco (29th January 2021)
  5. #593
    The oil cooler is pretty easy to do, I did mine when it was out of the car but it's just a couple of o rings and a few gaskets inside it.
    Would be much trickier in the car though. That one leaking would just be the large external gasket.
    https://patrolapart.com.au/product/g...ler-gasket-set
  6. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    MB (29th January 2021), Rossco (29th January 2021)
  7. #594
    483 Post(s)
    @MissusWinnie, can Chrisso come and please help Rossco this weekend, your blokes got skills & experience
    EDIT: Just confirming, the hills are an alcohol free vegan environment rest assured
  9. #595
    Cheers gents, sweet at least nothing to nasty by the looks of it, might do a Patrolapart trip soon, already have a bit of a list lol. . She's booked into Lilydale mufflers & towbars on Friday see how we go with the exhaust its currently finishing at the diff which isn't ideal so will be good to get that sorted and hopefully leave a good spot for water tank
  10. The Following User Says Thank You to Rossco For This Useful Post:
  11. #596
    483 Post(s)
    Top choice Rossco, he’s our valley favourite for all things muffler/towbar big & small too
    GQ Gramps scored a quick cheap new muffler and redirection only 2 weeks ago from old mate as well before suspension/arms work forthcoming.
  12. The Following User Says Thank You to MB For This Useful Post:
  13. #597
    Hmmmmm. would be good to confirm where that coolant is coming from mate. a pressure test as MB suggested would be a good start. If could be as simple as a Welsh plug or something. but need to get onto it, it should not be there for sure.
  14. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  15. #598
    Ghee thinking now though, How old is that motor mate? surely it has not blown a welsh plug? was that a fresh build?
  16. #599
    Yeah definatly a go to, happy to do whatever slightly obscure mods without fuss
  17. The Following User Says Thank You to Rossco For This Useful Post:
  18. #600
    Yeah tis, pretty certain it's coming from main oil cooler gasket. Also leaking coolant from bottom radiator hose clamp, it's tight but must just be elongated at the nut bit. . Another thing to the list lol. . .
  19. The Following 2 Users Say Thank You to Rossco For This Useful Post:
    MB (29th January 2021), MudRunnerTD (29th January 2021)
