Results 1 to 3 of 3
Thread: Siphon/jiggler hose GU Patrol
    Sep 2019
    Hi all, I’ve been travelling with one of these things onboard for sometime now only to be recently told that I probably can’t get it to work on either the main or sub tank.
    Experimented today.
    Confirmed.
    Has anybody got a way around this that doesn’t involve me completely removing tanks and necks? Or even another method or product of getting the fuel out if I need to?
    Thanks, Peter
    Expert dpetersen's Avatar
    Jan 2015
    Watarrka National Park
    6 Post(s)
    Quote Originally Posted by Peter Comber View Post
    Experimented today.
    Confirmed.
    Thanks, Peter
    You could always get a compressor and put it in the filler hole, block it with a rag. Disconnect the supply line from the fuel filter. Have done this a couple of times if I needed to get a bit of diesel out for something. Pain in the bum on your own but
    2006 4.2 tdi wagon
    TJM BullBar and bar work, Light bar & spotlights, Airtech snorkel, tradie rack, blocked egr, 2inch lift on 33s and a 3 inch exhaust to go with it all.
    Plenty more to come!
    Ballarat, Vic
    178 Post(s)
    I travel with one too, primarily because of concern that one day the sub tank pump may not work when I need it. I tested the jiggler in the sub tank when I bought it & it worked ok. Messy business, but better than running out of fuel when there's fuel in the tank. Mine is the 85litre sub tank on the cab chassis. The jiggler hose saves my back too, when filling from a Jerry.
