Results 11 to 20 of 44
Thread: Time for some new rubber
    Mar 2016
    Nandewar Ranges, NSW
    10 Post(s)
    Quote Originally Posted by Mickhead View Post
    Had one set of KM2s. 50 ks. On my 3rd set of Nitto trail grapplers. 295 70 17s on the wrangler 60ks a set They are fkn heavy but good.
    Still learning on the poo, have fed couragias and they are slippery on the bitumen in the wet! hey they were cheap!Attachment 82756
    Must be happy with them if you are on your 3rd set.
    Leaning towards the Nittos at this stage.
    Cheers.
    Sent from my campfire using smoke signals.
  2. #12
    Mar 2016
    10 Post(s)
    Thanks for your input @Winnie & @MB. Nitto's seem to be the go it seems.
  3. The Following User Says Thank You to VK2FMIA For This Useful Post:
    MB (5th January 2021)
  4. #13
    Toyos & Nittos seem to be getting good reviews of late. Toyos are cheaper than they were a few years back
    So far I'm happy with the Toyo RT's (Toyo equivalent to the Nitto Hybrid 'Ridge Grappler - but with a slightly more open tread pattern in the middle) I fitted fairly recently but have only done road mileage on them so far. A bit noisier than my previous Bridgestone D697 AT's but a lot quieter than a full mud tyre. No difference in fuel consumption & should be better off road with the more aggressive tread & less sidewall bulge at lower pressures. Better balanced than both sets of Bridgestones I've had too - requiring far less weights.
    Attachment 82754
    I reckon these look pretty good and the pic actually doesnt do them justice they look pretty impressive in the flesh for sure. If i was after a Touring Tyre these would get a serious look.
  6. #14
    Only all our honest new observations VK Mate!
    Please do consider @Cuppa’s Toyo’s too, he’s done a Fair Dinkum heap of research for his serious travelling needs out there and if Mud Terrains weren’t needed, reckon I’d copy cat that Legend Too
  7. The Following User Says Thank You to MB For This Useful Post:
    VK2FMIA (6th January 2021)
  8. #15
    Well done Dazman you Hipster
    Typing same time again likeminded Legend
  9. The Following User Says Thank You to MB For This Useful Post:
    MudRunnerTD (5th January 2021)
  10. #16
    Feb 2011
    Shed
    45 Post(s)
    Have a look at falken wildtreks. Put em on my 03 hilux. Quietest 4wd tyre I’ve ever used. They’re an AT. I used them in the Flinders recently and they were fine on very slippery outback roads when we got caught in the rain. Also no nicks at all after driving on sharp rocks. Mate has em on his Paj has done 80k and only just looking to replace them now
  11. The Following 2 Users Say Thank You to growler2058 For This Useful Post:
    MB (5th January 2021), VK2FMIA (6th January 2021)
  12. #17
    A few cans in, Tyres Tires
    Sadly have listened to Blokes too complain about great brands “Side Walls” in rocky shail shaving environments!
    Choose a tyre for your honest needs folks and “STOP” shagging the poor buggers through extremely piss poor line of sight!
    “First point of Alien Asteroid contact, it is a long walk home”
  13. The Following 2 Users Say Thank You to MB For This Useful Post:
    growler2058 (5th January 2021), MudRunnerTD (5th January 2021)
  14. #18
    Mar 2016
    10 Post(s)
    Thanks growler, will check them out.
  15. #19
    Mar 2016
    10 Post(s)
    I have just swapped my BFG KM2's for Kumho MT71. The load rating and construction was the same on paper, and the price difference enormous - $480 V $310 each. The ride is difference, does not feel as 'soft' as the BFG, and the tyre has a more square profile than the BFG, almost like a BFG All terrain. Kumho probably have a similar tire in the AT?
    Thanks for the suggestion PB.
    Had a look at the MT71`s & the MT51`s. The 51`s look like a hybrid, not quite as aggressive as the 71`s but more than the AT`s. Could be a good compromise & the price for all Kumho`s is reasonable too.
  16. The Following User Says Thank You to VK2FMIA For This Useful Post:
    PeeBee (6th January 2021)
  17. #20
    Mar 2016
    10 Post(s)
    S
    Thanks Cuppa. Sent off an online quote for the Toyo`s. Will see how they compare to the others.
