Results 1 to 10 of 15
Thread: How hard can it be?
    Jul 2018
    How hard can it be?
    Been to 2 automotive electricians in the last 3 months to have 2 redarc gauges fitted .. boost/egt and oil pressure/water temp with optional external temp and light dimming system ... nobody wants to do it? Is there some problem that I am not aware of? Is it that hard? Am I missing something?
    2013 GU y61 Patrol 3.0l
    84 Post(s)
    I have no idea how to help you, but it is such a relief you posted about lektricity. I thought you were going to talk about part of your body.
  3. The Following 2 Users Say Thank You to mudnut For This Useful Post:
    Avo (24th December 2020), BrazilianY60 (4th May 2021)
    Jul 2018
    hahaha you have cheered me up with that comment :-)
    477 Post(s)
    It’s not hard at all. Instructions are provided. As long as you have somewhere to pick up the boost pressure your sweet.
    Jun 2018
    25 Post(s)
    Fitting and hooking up the gauges isn't that hard, just time consuming.
    I documented my install with photos and wiring diagrams here (EGT/boost/dual temp and dual battery voltage):
    http://www.nissanpatrol.com.au/forum...d.php?p=792967
    I did a part two of the install a few posts after that one too.
    If you give it a go and have any questions, I'd be happy to try to help out with info if you need it.
  7. The Following User Says Thank You to Cremulator For This Useful Post:
    MB (25th December 2020)
    Do you want them to do sensors as well or just install gauges and wire up?
    Unless they are in a "multi-trade" workshop most auto sparkies won't be arrsed farting around with EGT probes etc.
    Much easier money to be made
    Might have more luck trying an Accessory Fitter tho they will probably balls up the dimmer.
  9. #7
    Jul 2018
    These are dedicated Auto electrics who both deal with redarc products .. they are both fully qualified and are not just the "installers" .. had enough of those clowns at the local Ironman dealership ... I already have a VDO EGT and boost .. but the boost has never worked properly even after buying 2 new gauges bcoz the 4x4 centre in Bunbury screwed them up .. the EGT works fine but I wanted matching gauges and a little more engine info .. hence the redarc gauges .. I would fit them myself (probably with help) but I buggered my arm up and just had surgery on the foot .. so not in any state to do much ..
  10. The Following User Says Thank You to timbo2410 For This Useful Post:
    the evil twin (28th December 2020)
  11. #8
    Jul 2018
    yes i wanted to do the sensors as well as the dimmer .. I also wanted the connection to the boost side checked as my VDO has never been accurate and that is from using 2 brand new gauges ... I can check boost via my OBD2 link via the ipad but I want to use the full ipad screen for navigation (have it split 50/50 navigation and engine parameters).
  12. #9
    Jul 2018
    great write up .. love the gauges .. what were they .. cant see from photo ..
  13. #10
    Jun 2018
    25 Post(s)
    Quote Originally Posted by timbo2410 View Post
    Oh yeh, I hadn't listed the different models in my write up.
    I fitted the Redarc G52-VVA and G52-BET gauges with GS-OWT1-4 and GS-UT-80 temperature sensors.
  14. The Following User Says Thank You to Cremulator For This Useful Post:
    MB (26th December 2020)
