Page 61 of 98 FirstFirst ... 5960616263 ... LastLast
Results 601 to 610 of 972
  1. #601
    Well after retracting my steps. I found the issue. Broken earth wire on the engine loom under the intercooler. I must have knocked it at some stage during the injector or intercooler instal or removal.
    Lucky I saw it, the broken wire had dropped down and was hiding under the manifold.
    Now to remove the new fan assy for a replacement.
  2. The Following 5 Users Say Thank You to mudski For This Useful Post:
    Bidja (6th December 2020), jay see (6th December 2020), MB (6th December 2020), PeeBee (6th December 2020), Rossco (6th December 2020)
  3. #602
    Awesome news Mr Mark we’ve got to happy when we find an easy fix like that cheeky little wire
    I’ll be sure to try “retracting my steps” too, is that just like a Michael J Moonwalk backwards around the vehicle once or twice for good measure?
  4. The Following 2 Users Say Thank You to MB For This Useful Post:
    mudski (7th December 2020), rusty_nail (7th December 2020)
  5. #603
    Haha yeah. Stopping for a moment, listening to what Phil said I was like, there’s only one earth point under the dash, where could it be?
    So I started doing the “moonwalk” and found it.
    MB (7th December 2020), PeeBee (7th December 2020)
  7. #604
    Patrol Guru Sprock's Avatar
    Jun 2015
    Heyfield Vic
    35 Post(s)
    Listening to Phil is enough to make anyone moonwalk around backwards 🤣
  8. The Following 2 Users Say Thank You to Sprock For This Useful Post:
    MB (7th December 2020), mudski (7th December 2020)
  9. #605
    My GOD, some more words of wisdom from the Mountain Giant - how are you Sprocky-doodle!!!
  10. The Following User Says Thank You to PeeBee For This Useful Post:
  11. #606
    Mudski GU Build Thread
    So I spent a good part of the day at Matfew’s place. He was kind enough to assist in the cable making of the winch. This guys needs a medal. Love his work.
  12. The Following 3 Users Say Thank You to mudski For This Useful Post:
    Avo (1st January 2021), jay see (29th December 2020), MB (30th December 2020)
  13. #607
    Just to show everyone the size difference in cabling, this next shot my finger is underneath the winch power cable from the TJM OX winch that was removed, which is now used as an auxiliary extension lead. You can see the size of the replacement cable attached to the +ive in the pic. Messive bro!
  14. The Following 2 Users Say Thank You to mudski For This Useful Post:
    MB (30th December 2020), MudRunnerTD (29th December 2020)
  15. #608
    Now I’m to doubt myself. I have pre wired the cable cab winch isolator and winch in/out switch. I have the in/out wires there the solenoid under the dash. Does this pic look right? Should the +ive batt wire I have in the pic be a constant power source or only when the ignition is turned on?
  16. #609
    Pretty sure I'm set up with ignition, if it's right or not I have to idea..
  17. The Following User Says Thank You to jay see For This Useful Post:
    mudski (30th December 2020)
  18. #610
    177 Post(s)
    Am I seeing right ? You're running your winch with that cable on a 70A breaker ?
