Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 68
Thread: Harrop Eaton ELocker Versus GU Family Wagon Auto Hubs
  1. #51
    84 Post(s)
  2. The Following 2 Users Say Thank You to mudnut For This Useful Post:
    Bidja (3rd December 2020), MB (3rd December 2020)
  3. #52
    483 Post(s)
    You installing @MB - need my tap for the diff fitting? Watch out for the location, sure you won't get caught twice?. Sing out if you need it. Is this for front or rear?
    That would be awesome again thanks Philstar Mate!
    Utes loaded up now and off to the factory to do it down there today
    Finally tracked down where I posted last installation booboos on the family wagon here:
    What did you do to your Patrol today!
    https://r.tapatalk.com/shareLink?sha...5&share_type=t
    Will kindly have access to a proper press today from the mechanic next to work and I’ll be sure to drill the 1/4” NPT bung further away from the crown this time around
  4. The Following 2 Users Say Thank You to MB For This Useful Post:
    Bidja (3rd December 2020), Winnie (3rd December 2020)
  5. #53
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    40 Post(s)
    That was a good display and noted that his lockers were the Terrain Tamer that use the new 4 pin design Harrop Eaton ELocker. Been checking these out and they no longer use the cam ramp disc plate with the ball bearings to provide disc plate separation to move the pins to lockup assy. Harrop now use 4 pins in lieu of the ball bearing and at disc plate rotation/engement,the pins force a lug profiled lock plate to engage with the housing. Harrop claim a more positive lock engagement and axle rotational lag of max 1/8 turn in lieu of 1/2 turn experienced with earlier design.
    For Info: Posted Harrop Eaton ELocker video of current build/operation
    https://www.youtube.com/watch?v=nT_H6rpd-Ck
  6. The Following 2 Users Say Thank You to Bidja For This Useful Post:
    MB (3rd December 2020), mudnut (3rd December 2020)
  7. #54
    483 Post(s)
    Step #1 completed
    Crikey some of these 35 year old OEM bolts were tight
  8. #55
    483 Post(s)
    Mark up the bearing carriers:
    A single ‘snake bite’ left:
    Double ‘snake bite’ right:
  9. #56
    483 Post(s)
    A quick ‘Boiling Water’ bath expansion for the crown to fit over the new ARB center:
    And....this is where I stuffed up last time, make sure to utilise a correct sized press for the bearings!
    It’s the tiny air hole area on the journal that needs to be scratch free!!
  10. The Following 2 Users Say Thank You to MB For This Useful Post:
    10G (8th February 2021), Winnie (3rd December 2020)
  11. #57
    Loving the photo journey, never seen how these are installed before.
  12. The Following User Says Thank You to Winnie For This Useful Post:
  13. #58
    483 Post(s)
    Remembering from last time, found the ARB instructions a little misleading in regards to drilling and tapping the airline into the housing. Fingers crossed this slightly altered location should create a straight line away from the crown leading edge:
    Chose to centralise the airline between two upper housing bolts for hopefully easier reinstall also:
    Thank you kindly @PeeBee Mate for driving your 1/4 NPT tap all the way out again, appreciated heaps
  14. The Following 2 Users Say Thank You to MB For This Useful Post:
    10G (8th February 2021), PeeBee (3rd December 2020)
  15. #59
    Jul 2017
    40 Post(s)
    @MB Noticed U wiped off the hands for assy_looking good mate
    After 30 yrs of hard yakka, how do teeth look (crown/pinion wear mark / shine) and out of interest did U check backlash with indicator_ nom 0.010"??? is the go not sure there..
  16. The Following User Says Thank You to Bidja For This Useful Post:
  17. #60
    483 Post(s)
    All looks pretty decent inside John Mate, tis only the front diff though so far less wear expected
    Set backlash by feel under mechanics guidance next factory over
  18. The Following 2 Users Say Thank You to MB For This Useful Post:
    Bidja (3rd December 2020), Plasnart (3rd December 2020)
