Page 57 of 64 FirstFirst ... 5556575859 ... LastLast
Results 561 to 570 of 635
Thread: Rosscos GQ Rejuvenation
  1. #561
    Haha, yeah. . . Plan is to pull the transfer off, then do the 5th gear installation myself which you can do from the back of the box whilst still in car, then take the transfer to YV 4WD to do. Wouldn't have a clue which bit goes where no instructions just a box of bits lol but give it a crack. . Was umming and arring about low range, didn't want to go crazy low so it was between the 20 something and 40 something and dude talked me into the 40s so should be good hopefully !! ABs seems happy with his and is exact same setup . .
    Wow mate you're unreal! So jealous... Just want those reductions!
    Rossco (6th November 2020)
  3. #562
    @AB has 63% reductions which are the custom sets. Marks do the 43% and the 83%
  4. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    MB (6th November 2020), Rossco (6th November 2020)
  5. #563
    Ah rodger, that kinda makes me happy, definatly glad didnt go with the 20 whatevers. Looking for slightly lower but not a crazy crawler. Sure I'll be happy with these, full low ones wouldn't suit my driving style I think whatever that is lol. .
  6. The Following User Says Thank You to Rossco For This Useful Post:
  7. #564
    483 Post(s)
    Awesome choice Rossco, personally reckon your circa 150rwkw TD42Ti with 43% reduction through to your 4.6 pumpkins powering 35’s will be the absolute perfect Vic-HC match IMH Acronym Opinion
    Our 6.5NA grunter slug is a wee bit too slow with 63% through to 4.3’s powering the same rubber sized boots.
    You’re going to Love IT
  8. The Following 2 Users Say Thank You to MB For This Useful Post:
    MudRunnerTD (6th November 2020), Rossco (6th November 2020)
  9. #565
    483 Post(s)
    Welcome to borrow our die grinder when the time comes too mate, I believe the higher 20’s from Marks are the only gears that don’t need slight internal casting alterations to fit, 43% I’m pretty sure does require a whisker or two off to fit.
  11. #566
    Cheers Markie, seriously under the pump with work ATM so Yarra Valley 4WD have kindly offered to sqeeze in transfer case rebuild this week provided its out of the car. Also got talked into rebuild kit as it has around 460K in it crazy not to whilst in bits I spose. . Called patrolapart and were fully booked till December the 8th!! Hoping the 5th gear is a relatively straight forward install, from what I've heard different sound too bad. .
  12. The Following User Says Thank You to Rossco For This Useful Post:
  13. #567
    483 Post(s)
    Bugger the box sound Mate, happy to yell louder as your New Navi soon pretty please
  15. #568
    Haha woops, typo meant doesn't sound too bad (to install). . Definatly looking forward to longer legs on the highway, should be much better, hope'n. . . But yes keen as mustard to get the old girl out there
  16. The Following User Says Thank You to Rossco For This Useful Post:
  17. #569
    483 Post(s)
    A quick safety word of warning Rossco and others no doubt closely following your Magnificent Silver Brumby rebuild
    We do honestly need to relearn our twucks once reduction gears are installed. Not so much on climbing/crawling upwards but descending on very long tracks with varying terrain can become hazardous until familiar with your new set up...torquey...get up
    A known experienced decent for me was that I ran out of RPM in a now extra slow 1st LR and couldn’t regain momentum traction needed.
    I now select 2nd LR on that decent as it becomes a traction balancing act of rock scrabbling through to slick sliding and then back again if that makes sense.
    Worst thing we can do is change our gear minds half way up or down and hit ‘Angel Gear’ (NO GEAR) and away we ALL go with horrific momentum consequences :-(
  18. The Following 2 Users Say Thank You to MB For This Useful Post:
    growler2058 (6th November 2020), Rossco (7th November 2020)
  19. #570
    I'm starting to feel ill. I understood more than half of that.
  20. The Following 4 Users Say Thank You to PeeBee For This Useful Post:
    Avo (7th November 2020), growler2058 (7th November 2020), MB (6th November 2020), Rossco (7th November 2020)
