Page 53 of 74 FirstFirst ... 5152535455 ... LastLast
Results 521 to 530 of 734
Thread: Jay see 1997 GU build up
  1. #521
    I do get what you’re saying John-TD Mate but I’ve been running two of them (one ute/one wagon) for maybe 3-4 years now and original advisors of them finding trouble free too for decades I believe?
    The rough hack handling low potential of the clip bending for me far outweighs other similar options getting mud clogged mechanisms and rendered useless when in desperate need out there.
    Eliminating Bow Shackles and simply connecting these great big hooks direct to tree trunk protectors (both ends at once) has been a thankful honest game changer for us
  2. The Following 2 Users Say Thank You to MB For This Useful Post:
    jay see (13th October 2020), MudRunnerTD (13th October 2020)
  3. #522
    476 Post(s)
    Where did you get the hook from John. I still need to get one for mine.
  5. #523
    Roadrunner sell em . .
  6. The Following User Says Thank You to Rossco For This Useful Post:
  7. #524
    Yeah mine looks exactly the same and got it from roadrunner.
    I prefer that style hook as well.
  8. The Following User Says Thank You to Winnie For This Useful Post:
  9. #525
    Correct gents. Got it and the rope from Roadrunner, they also have the larger 5.3t.
  10. The Following 2 Users Say Thank You to jay see For This Useful Post:
    mudski (13th October 2020), Rossco (13th October 2020)
  11. #526
    Keble’s also, many rigging type stores closer for your ‘Click & Touchless Collect’ on your way home from Truck work Mr Mark
  12. The Following User Says Thank You to MB For This Useful Post:
  13. #527
    Got some prep work done today to finish off the winch tomorrow. Drilling into the drum there must be two parts. The drum must rotate on another shaft. So I drilled and tapped then rotated the drum to clear the inner shaft (this doesn't move)shortened the bolt to suit and it works. Dummy fit to make sure that it all lines up and painted the plate black. Will weld in the plate, attached the rope and bolt up the fairlead.
  14. The Following 2 Users Say Thank You to jay see For This Useful Post:
    MudRunnerTD (17th October 2020), mudski (17th October 2020)
  15. #528
    476 Post(s)
    Make sure that bolt thread length is only enough for the eye and the thread in the drum mate. The brake is inside the drum so the bolt must not protrude through. Just in case you weren’t aware....
    Coming along real nice though John. Are you going to get the bar sandblasted and powder coated when your done.
  16. The Following 2 Users Say Thank You to mudski For This Useful Post:
    jay see (17th October 2020), MudRunnerTD (17th October 2020)
  17. #529
    Yeah, I worked out that bit after I drilled. I span the drum to clear the hole in the brake. I might take a little more off the bolt,
    Not going to do anything about paint. A new paint job on just the bar won't suit the rest of the car.
  18. The Following User Says Thank You to jay see For This Useful Post:
  19. #530
    Job done
    Good from far far from good, but hey it works. I know that I said that I wasn't going to paint the bar, but the paint blistered after welding in the plate. Had some black paint and touched up that area and it looked pretty good, so I washed down the whole bar with some mineral turps and gave it a fresh coat.
    Now we really need to go on another weekend away so I can tension the rope.
    Still need to sort out a winch switch on the bar and get some wires up to that roof console, but that's for another time.
  20. The Following 5 Users Say Thank You to jay see For This Useful Post:
    10G (19th October 2020), Cremulator (17th October 2020), MB (17th October 2020), mudski (17th October 2020), PeeBee (17th October 2020)
