Results 1 to 7 of 7
Thread: Cruise control pinout td42
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    Hi all,
    Anyone have or know where I can find a pin out/wiring diagram for the cruise control unit on a GU3 td4.2?
    I had a bit of a dig through the old posts but I couldn't find one.
    I think I'll be able to work out what I need to without one, just might save me a bit of time.
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    if you ever find it, can you flick me a copy, as I want to put CC onto my '99 DX
    Jun 2018
    25 Post(s)
    The post I put up about fitting steering wheel audio controls has some reference pages from the workshop manual that show the cruise control buttons wiring.
    http://www.nissanpatrol.com.au/forum...d.php?p=787897
    Have a look at pages EL48 and EL163 and the M28 pin configuration.
    Is that what you are looking for?
  4. The Following 2 Users Say Thank You to Cremulator For This Useful Post:
    0-TJ-0 (21st September 2020), Bigcol (21st September 2020)
    May 2016
    8 Post(s)
    so you want the speedo wireing ? I don't think the TD 42 has the smarts . its the very basic system on these old gals .
    Cruse control is a lot of work . Will follow this thread as I have been looking for an easy way out to do this
    Jan 2017
    South Australia
    11 Post(s)
    Thanks all, and thanks @Cremulator . I've had issues navigating that WSM in the past but got it worked out and found what is looking for.
    When I work out the best way to fix my issue I'll definitely post it here. It doesn't appear common, but might help someone.
  7. The Following User Says Thank You to 0-TJ-0 For This Useful Post:
    Cremulator (21st September 2020)
    I have a autron CC thats not working , can anyone tell me where it is and Ill trace wires from there
    TIA TD
    Jan 2017
    South Australia
    11 Post(s)
    The factory unit is in the driver's side foot well kick panel.
