Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Removing NATS (Nissan Anti Theft System) from GU III 4.2TD Injector Pump
    Feb 2012
    Lakes Entrance
    Quote Originally Posted by drgtr View Post
    Thanks Mate
    I haven't had issues (touch wood) but I might get my mechanic friend to do it for me.
    SO basically in a nutshell
    Smash that black box open to get to the 1 wire protruding out. Then rejoin the middle loom wire to that one protruding wire?
    I guess the scariest part would be hopefully not wrecking that 1 protruding wire in the process..
    There's no way I'd do it that way. Once you take the pump out it's so simple to run any of the new easyout style of screw extractors into the two screws holding the black box on and it comes off. Absolutely zero risk of damaging wiring, injector lines or pump. Not a lot more work either. Mark the position of the pump before you take it out and make sure it goes back at exactly the same spot so the pump timing doesn't change.
    Dave
  2. #22
    Jan 2018
    Hey Dave
    I been told taking the pump out is really hard work though?
    How long did it take you
  3. #23
    Advanced Lionel84's Avatar
    Feb 2013
    Brisbane, QLD
    Hey Dave
    2 people it took a whole day, and one of them is a mechanic, as per Dave's concise explanation.
    2007 Nissan Patrol Y61 Wagon AT 2009 ZD30CRD Engine
    Snorkel, Tillex, HPD Intercooler, 3" King Brown Exhaust, 2" Bilstein Lift, Steel Bar and 12000lb Winch, Engine Bay Lighting
  4. #24
    176 Post(s)
    Just read this, not realising until I saw mention of Yendor that this is an old thread. He was such a good resource to this forum! Yendor ... if you're out thee somewhere I miss you!
    The read sure made me glad that us Dx owners don't suffer from the dreaded NATS.
  5. #25
    Feb 2012
    Lakes Entrance
    Sorry I hadn’t seen the earlier question but as Lionel said. Took a whole day to get pump in & out. About 2 minutes to remove the NATS black box with the Alden proGrabit. Few mintutes to tweak the wiring to bypass it. Most of the work was getting the pump out & back in again but given the grief the other methods could cause I’d do it this way again any day of the week.
    Cheers 🍻 Dave
  6. #26
    Quote Originally Posted by davejones View Post
    Cheers 🍻 Dave
    Wood Chisel worked for me....
