Results 1 to 10 of 12
Thread: Micro Short Circuiting on Solar Panels
    FNQGU's Avatar
    Jun 2013
    Cairns, Queensland
    21 Post(s)
    Soooo....
    Has anyone had this happen on their solar panels before? The squiggly lines across the solar cells. It doesn't look good, but do you know what it is and what causes it?
    I have had it suggested that this is a micro short circuit, which sort of makes sense, given it looks vaguely like a lightning strike, but in reality I have no idea.
    There is a bit of water on the panels too, so ignore that. I had just washed everything after a trip when I noticed the weird lines.
    Nov 2019
    Perth
    5 Post(s)
    All of my solar panels end up with those appearances ... they still work enough to keep my happy
    2008 CRD Auto Wagon
    Can you detect a loss of output? Never seen anything like this before either.
  4. The Following User Says Thank You to PeeBee For This Useful Post:
    FNQGU (24th August 2020)
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    how old are the panels?
    looks to me like when you crack a circuit board, but not break it completely
    do you have a gap between the roof and the bottom of the panels?
    FNQGU's Avatar
    Jun 2013
    Cairns, Queensland
    21 Post(s)
    The panels are about 3 years old. Set up with a gap between roof and panel of about an inch. I've been suspicious of a drop in output but haven't measured it as yet. I think that will be today's job. I was doing a fair amount of driving recently and not relying on the panels so didn't notice it as much as I might if I was camped up. Normally though, the panels will have me fully re-charged by say 10am if in good sunlight. On a couple of days I noticed it was still charging at 11am and through till nearly lunch time, but didn't think much of it as I was running the fridge as a freezer and overnight the battery would have had a lower SOC. Will take a closer look at output today.
    176 Post(s)
    Have re-posted on a friend's forum where I hope to obtain an experienced solar opinion. Will get back to you if/when I hear. Haven't see this before myself.
  8. The Following User Says Thank You to Cuppa For This Useful Post:
    176 Post(s)
    Ben, 2 responses so far. They refer to the issue as a 'solar worm. Uncertain as to cause, but pics look virtually identical to yours.
    One from a friend who reported same concerns as you back in 2017. Measuring showed no drop in output at the time. He reports that 3 years on the panels are still working fine & producing the same rated output. These were bought from Low Energy developments & produced by TN Solar. Co with the following label on them.
    One example of a number to show the 'worm' on his panels
    Second from another friend who recently bought a job lot of cheap used panels ($14 each for 250w 24v panels). He commented "About half had that 'worm' on them. Some really bad. Testing them in bright sunlight showed very little drop in performance at all".
  10. The Following 3 Users Say Thank You to Cuppa For This Useful Post:
    FNQGU (24th August 2020), jack (24th August 2020), PeeBee (24th August 2020)
  11. #8
    FNQGU's Avatar
    Jun 2013
    Cairns, Queensland
    21 Post(s)
    Thanks Cuppa, much appreciated. The 'worm' seems to be only on two cells so far on one of the two panels. Another bit of feedback I received says that the panels could be on the way out. It will be interesting to measure the output and see if there is any difference to the ratings.
  12. #9
    176 Post(s)
    Given that it will be difficult to replicate the conditions under which the rating is made, it probably makes sense to just measure the relative output of both panels to compare.
  13. #10
    176 Post(s)
    And another response, this from the chap I'd been hoping would reply. He runs a business building & installing lithium batteries & their associated solar systems. I had not mentioned any possibility of 'arcing'. This is his response to seeing your photos.
    The wiggly lines are just what they look like, an arc between the grid wires in those modules. If you look real close, you can see the bubble of copper built up each side if the arc line. If the arc repeats too often in the same place, those tiny threads actually get burnt through and module loss starts to become panel output loss. The output voltage open circuit will be the same as the specs on the back of the panel say, but the short circuit current starts to drop off the more damage there is in any module.
    The cause, generally poor wiring practices, either panels connected in parallel with under size cable and each panel added in to this under size wire. eg. 6mm auto cable can carry the output of a 150w 12v panel, not 2 or 3 panels all paralleled into the same single run of 6mm auto cable.
    The problem starts with the panel getting hot because it can't get all its output through the wire because of a resistance build up, the weakest modules get the hottest in the panel that suffers with the most resistance, generally the panels further down the string. Add a larger capacity panel to the same parallel string and real problems start to emerge.
    When the solar controller determines the battery is full or needs to drop to a low voltage such as the step from boost or bulk charge down to float charge. The only way it can do that is to stop accepting any output/input from the solar. The solar array voltage now climbs to open circuit voltage, the hottest modules have the lowest output so therefore the lowest push back against current coming in rather than current going out, so the module becomes a heater and finally an arc runs across the module trying to reduce the current and voltage, a short circuit. This path is now slightly burnt so a carbon track is laid, this makes the path for an arc to travel down easier than the first time, and so the arc continues to burn across the module until it fails.
    This is why blocking diodes were included in all earlier built solar panels. When domestic roof top solar started, panels were connected in a single series string to build the voltage and not the current. Bypass diodes remained but the blocking diode became redundant resulting in a cost saving for the panel manufacturer and the buyer being none the wiser.
    The arc across the panel is the end result, same thing happens when more than 1 series string is connected into the MPPT controller, the high output from one string reverse flows into the string with a shaded panel, then the same process as mentioned about happens.
    My reading of your situation then Ben, combining the info from all sources, is that the panel is on the way out, but it could take potentially a long time to fail & let you down. If feasible fitting a blocking diode inside it's rear junction box, may well prevent any further deterioration, as might increasing the thickness of copper in the wire between panels & to the the regulator.
  14. The Following 3 Users Say Thank You to Cuppa For This Useful Post:
    Bigcol (25th August 2020), FNQGU (25th August 2020), mudnut (24th August 2020)
