Results 1 to 6 of 6
Thread: GQ Steel bar behind quater pannel in the way of Snorkel
    Advanced Dasa's Avatar
    Aug 2019
    North central VIC
    So I am unable to find any pictures of other snorkel installs with this in the way, has anyone seen this before and do I just cut through it as well?
    94 GQ coil cab TD42
    20150907_123122_zpsukkudzpu.jpg~original.jpg20150907_123106_zps75gcaxmj.jpg~original.jpg
    Hack away brother. I seriously doubt it will be missed. Just remember. Measure twice, cut once.
    Jan 2018
    Pt Augusta SA
    When I installed mine last year I just cut through it. No damage has occurred in that area.
    Pete
    I assume you are trying to fit a larger snork through that same hole yeah? I cut slits arounf in and bent the tabs to make it bigger. There is not much room to work there. Cold chistle is your friend.
  5. #5
    Aug 2019
    North central VIC
    Thanks for the quick replies.
    Planing to use some scraps of 3" stainless I have laying around which will fit through the hole no problem once I hack that bar out of the way.
  6. #6
    Quote Originally Posted by Dasa View Post
    No probs. I went 4" through there on my GUIV. It will fit mate.
