Results 11 to 20 of 23
Thread: GU Door Striker Bolts won't budge
    Jul 2020
    Central Queensland
    Thanks all. Yes after trying a regular Phillips head I dragged out the impact driver (the one you bAsh with a hammer)
    I’ve stripped the screw heads. I’ll try a bigger hammer but failing that yes I’ll try welding (but don’t want to bugger my paint)
    Otherwise grind them off
    Yeah “Easy out” LOL I love that name.
  2. The Following 2 Users Say Thank You to Njrqs For This Useful Post:
    PeeBee (27th July 2020), Rossco (26th July 2020)
  3. #12
    477 Post(s)
    A quick zap with a mig shouldn’t put enough heat into the area to wreck the paint.
  4. #13
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    A lot of impact drivers come with a No 2 phillips head bit. What you want for that sized screw is a No 3 bit. Unless it is really flogged out the correct bit should still do the job.
    Also, did you make sure the impact driver was locked in the correct direction before hitting it with a hammer? You have to pre set them to go either left or right. Also, you should turn the impact driver slightly in the direction you want the screw to turn to give the driver a bit of preload, and then give it a hit with the hammer. I have used mine dozens (if not hundreds) of times - especially when working on motorbikes - and have never had an issue, even with the most stubborn of screws.
  5. #14
    Jul 2020
    Central Queensland
    Thanks Bill and co. Yes I’m sure it’s going the right way. I’ll have to try the mig option as I’ve buggered the screws now.
    Good source for new ones?
  6. #15
    Quote Originally Posted by Njrqs View Post
    Hi all.
    Bought new drivers door striker as my rubber covering was worn. Cannot get the bolts out. Have soaked them in Rostoff and used impact driver. No luck.
    Any ideas? Top bolt has some yellow paint mark on it. Unsure what that is for.
    out of curiosity can you upload a pic mate?
  7. #16
    482 Post(s)
    Possible idea here Njrqs Mate?
    Try a solid 10mm -ish punch/real smack ( no greater than the size of your pan bolt head) to shake up the OEM paint and years of great service.
    Truly just did this the day before last on an old Louisville twuck swapping sides as they no longer make em :-(
  8. #17
    Patrol Freak garett's Avatar
    Jan 2015
    north
    21 Post(s)
    been using a punch to turn bolts/screws sorta like the old cold chisel trick for nuts. i also have a removal kit that u drill a hole hammer a bar in then slide a nut onto the bar, works unlike easyouts.. but i must say the punch trick works better than the extractors i've tried.
  9. #18
    Jul 2020
    Central Queensland
    Thanks again all. It's in the "TFH basket" for now !!
    Oh and here is the photo someone asked for.
  10. #19
    I would drill the screw out, diameter no bigger than the root diameter of the screw, maybe a hair less, then it will simply fall out - guaranteed.
  11. #20
    Sep 2018
    queensland
    3 Post(s)
    use an angle grinder or dremmel and cut a flat slot in it. then use a flat screw driver to try turn it out
    the heat from the grinder might help to.
    not saying it will work but that method has worked for me in the past in some situations
