Results 1 to 6 of 6
Thread: Drop down fridge slide in to a Gq
    Expert First Pooy's Avatar
    Mar 2018
    Has anyone else installed a MSA DS40 drop down fridge slide on top of the Titan draws in a Gq ? How did you manage to keep it on the left side to utilise the draw slide ? because it hits the latch if you centre it and when you drop it down did it clear everything with out using the Titan slide ?
    I've got mine in a GU series 1(don't know if it's different to a GQ) on a slight angle, so when it's out and coming down it just misses the little barn door. You do need to hold it away from the door or it will scrap the top of the door. With it fully down I can open the right side draw with no problem.
    I'll see if I can get some more pictures. Is there any shots you want
    Loved one on an old DX leafy 3,400kg GVM ute although wouldn’t recommend on a 3,040kg wagon sorry gents :-(
    Mar 2018
    Why is that ?
  5. #5
    Mar 2018
    Thanks for that and yeah there is a difference on the Gu the body is wider and I think my be the roof is a bit higher so that puts the centre catch over for you plus I also realised that my fridge is thinner and teller where other are wider and shorter which would have them passing under the centre catch, so the only fix for me is to lose the extra slide length and move it to the right side but thanks for the pictures at least is shows me that the slide will come out and clear the bumper off the draws.
  6. #6
    Quote Originally Posted by First Pooy View Post
    Why is that ?
    G’day FP mate, only meant they are super well engineered pieces of fulcrum excellent kit, albeit they are super heavy brother!
    IMHO, skin out the back of your truck and use lightweight low down slimline fridge slides on its bed with all if your tucker in say ‘ Expedition Boxes’ :-)
  7. The Following 2 Users Say Thank You to MB For This Useful Post:
    Cremulator (13th July 2020), PeeBee (13th July 2020)
