Results 1 to 9 of 9
Thread: Immobiliser Issue?
    Expert TheFlyingBadger's Avatar
    Oct 2010
    Perth
    Immobiliser Issue?
    My ute (2004 TD42 w/after market immobiliser) is being a PITA.
    When i turn on the key, i get all the lights I expect (if the immobiliser's doing it's magic i don't get the glow plugs etc) - but when i turn the key to start everything turns off. I'm pretty sure it's not a battery issue as i've got 13V at the battery.
    I'm baffled as to what's going on....
    Full disclosure - the ute *may* have gotten a little damp the last time it was playing out.... this probably opens up the possible issues to include starter motor related stuff - but would that just cause the dash lights to turn off ?
    Jon
    Check your fuse block for moisture or a blown engine mangt fuse oe even dislodged one. Check your earth connections and also if you have a trailer plug connected that is full of mud - basically, the search begins.
    Oct 2010
    Perth
    Joy......
    Jon
    What was it?
  5. #5
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Clean your battery connectors.
  6. #6
    WA Wheatbelt
    23 Post(s)
    Quote Originally Posted by TheFlyingBadger View Post
    [FONT="]My ute (2004 TD42 w/after market immobiliser) is being a PITA.[/FONT]
    [FONT="][/FONT]
    @TheFlyingBadger With my knowledge of vehicles, you've answered your own question....it's the baffles. lol.
    How's it going?
  7. #7
    Nov 2019
    Perth
    5 Post(s)
    +1
    Sounds like loose/dirty connections
    2008 CRD Auto Wagon
  8. #8
    84 Post(s)
    If all else fails, look for damage caused by rodents. I've had a vehicle do strange things after rats had chewed some cables together.
  9. #9
    Oct 2010
    Perth
    Yeah, unfortunately the wife was right. It's the starter motor... *apparently* i'm not meant to drive it through puddles deep enough to cause the rear pod to flood...
    Jon
  10. The Following User Says Thank You to TheFlyingBadger For This Useful Post:
    0-TJ-0 (8th July 2020)
