Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 63
Thread: Zd30 common rail overheating
  1. #41
    Jun 2020
    thanks, but so many suggestions.. so many possible causes.. 🙇*♂️ anyone know someone in. Brisbane who can help?
  2. #42
    Quote Originally Posted by nipagu7 View Post
    i have heard of thermostats being put in upside down as well . wonder if this is the cause ?
    I heard to only use Genuine NISSAN thermostat.
    After market are dodgey.
    It may not of been said yet ,but only do one thing at a time
    that will let you know what the problem is, hope you sort it.
  3. #43
    Quote Originally Posted by ReggieRay View Post
    Yo again Ill look through my contacts and see if I can find someone.
  4. #44
    Jun 2020
    thanks.. hate to keep throwing money down the drain on things that turn out not to be the problem..
    new thermostat is genuine NISSAN
  5. #45
    Legendary happygu's Avatar
    Reggie,
    Was the new Radiator Brand New, or new to you ( as in second hand from another vehicle )?
    Brand new should be fine, but new to you could still mean the radiator is the problem ( as you mentioned heating up at high speed, and normal around town )
  6. #46
    Jun 2020
    brand new aftermarket radiator
  7. #47
    Do you know if the new radiator has the same number of 'Fins per inch' as the factory original? I replaced a factory radiator in a Merc G Wagen with an aftermarket unit and they reduced the FPI. The result was inadequate cooling and the vehicle radiator got so hot it actually radiated the heat into the a/c condenser and would lock up the compressor with the higher pressures - was a bloody expensive fix, but a simple cause. Might pay to see if this can be checked?
  8. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    Mickhead (20th June 2020), pollenface (20th June 2020)
  9. #48
    Sep 2018
    queensland
    3 Post(s)
    i've seen previous threads on forums where people say the after market radiators dont work as well. afew people say they will only ever use genuine even though they cost more.
  10. #49
    Jun 2020
    appears to be identical..
  11. #50
    477 Post(s)
    Well it seems the only things you haven't done is replace the water pump, the temp sensor and flushed the cooling system. Pick the cheapest and work from there.
  12. The Following User Says Thank You to mudski For This Useful Post:
    threedogs (23rd June 2020)
