Page 952 of 1057 FirstFirst ... 950951952953954 ... LastLast
Results 9,511 to 9,520 of 10561
  1. #9511
    Expert Dingbat MB TD42's Avatar
    Jan 2018
    Perth WA
    @Avo Noice. Hey have you thought about protection for the sides? Like clear wrap or some of that stuff I think it's called Rhino Hide or something??? Looks so bloody nice, just too hard to go and scratch it up
    No need...Only drives it to the beach to fish or to me mum's house to fix my rig...lol
    Quad-Drive 4WD Club...Western Australia
    We're all here coz we ain't all there...
  2. The Following 2 Users Say Thank You to MB TD42 For This Useful Post:
    Avo (28th May 2020), MB (14th June 2020)
  3. #9512
    I have looked at bush barriers....they do look good
    To be honest where we live after this photo I drove home 40 km and it was filthy...just off the road not even on gravel..somethinv you get use to...when we go to the city we wash it n make it look nice,otherwise,it's a car
  4. The Following 2 Users Say Thank You to Avo For This Useful Post:
    MB (14th June 2020), MB TD42 (29th May 2020)
  5. #9513
    198 Post(s)
    Completed the second rear seat frame, all painted, just stuck a layer of softish poly foam to add some cushioning, should do the trick.
  6. The Following 3 Users Say Thank You to PeeBee For This Useful Post:
    Clunk (3rd June 2020), MB (14th June 2020), mudnut (1st June 2020)
  7. #9514
    May 2016
    lower west victoria
    30 Post(s)
    I actually did something other than move it out of the garage for a change.
    Replaced, oil, air & fuel filters & engine oil.
    Cleaned out catch can and cleaned MAF.
    Lubed up shock adjusters & cut my thumb.
  8. The Following 2 Users Say Thank You to 10G For This Useful Post:
    0-TJ-0 (1st June 2020), MB (14th June 2020)
  9. #9515
    Ballarat, Vic
    176 Post(s)
    Having fitted both a new headlight wiring harness & a LED lightbar I waited for a nice dark night, before the moon came up over the nearby hill to see what they were like. In short 'Incredible'. I suppose everyone here who has fitted a light bar or has a mate with one already knows how bright they are, but I had only seen videos of them in action. Last night was the night - very impressive. I did note too that my headlights are whiter & brighter, & whilst effective my old IPF driving lights are very yellow in comparison. The headlight aim was way off in both planes though, & the IPF's needed adjustment as I had previously had them pointing outward to illuminate the sides of the dirt road I used to live on, in order to be able to see the wombats , roos & deer. I am confident that the lightbar will take care of that function now, more importantly if/when we find ourselves driving rough & washed out outback tracks at night again, that I will now be able to see just what I'm driving on! Has to be a good thing!
    The lightbar came with it's own wiring harness intended to connect in to a standard set up. Likewise the Pirahana Superloom was designed for much the same, & of course the Ex Telstra had already had work, adding Nissan branded relays for the IPF's. In the end it was fairly simple to work out what wires to use & not use. I have chosen to leave the switch for the lightbar under the bonnet for the time being. I used the existing IPF wiring, post Telstra relay, to trigger the lightbar's relay, & so I am using a single switch on the dash to turn both lightbar & IPF's on together when on high beam. This will be my 'Offroad' set up. For on road I just switch the lightbar off under the bonnet
    Will go out for a drive tonight to check my aiming adjustments done undercover today using the huge sliding doors to aim at, surprisingly it was dark enough to see what I was doing.
    There are a pair of H3 Philips 'White Vision Ultra' 55w globes in the post to fit in the IPF's when they arrive. They are advertised as the whitest halogens which are road legal, & +60% distance. I'm hoping they will be better than the very yellow Repco 100w +30 globes currently in them & give the alternator an easier time too.
    Whilst the lightbar is super bright (Stedi 27.5" single row 3301) I was pleased that when switching to dip beam - just the headlights, that I could still see reasonably well & it isn't like momentary blindness.
  10. The Following 9 Users Say Thank You to Cuppa For This Useful Post:
    Cremulator (11th June 2020), jay see (14th June 2020), MB (14th June 2020), Mickhead (11th June 2020), mudnut (11th June 2020), PeeBee (11th June 2020), Rossco (11th June 2020), Touses (12th June 2020), TPC (14th June 2020)
  11. #9516
    We had to replace the power steering pump on the old 1995 GQ work ute :-(
    I always assumed they were good for 30 years, not a measly 25 :-)
  12. The Following 5 Users Say Thank You to MB For This Useful Post:
    mudnut (14th June 2020), PeeBee (14th June 2020), Plasnart (14th June 2020), Rossco (14th June 2020), rusty_nail (14th June 2020)
  13. #9517
    .......... TPC's Avatar
    63 Post(s)
    I have highlighted something in your write up that just doesn't fit.
  14. The Following 3 Users Say Thank You to TPC For This Useful Post:
    0-TJ-0 (15th June 2020), Cremulator (17th June 2020), Rossco (16th June 2020)
  15. #9518
    Ballarat, Vic
    176 Post(s)
    Not sure I understand Tony - try substituting 'In short incredible' with 'Briefly, they were incredible" or perhaps 'In short, they were incredible' ??
  16. The Following 2 Users Say Thank You to Cuppa For This Useful Post:
    Cremulator (17th June 2020), PeeBee (15th June 2020)
  17. #9519
    476 Post(s)
    What did you do to your Patrol today!
    Bitta wiring the new light switches in and the new winch switches in where I had the light switches.IMG_3070.jpg
  18. The Following User Says Thank You to mudski For This Useful Post:
    PeeBee (17th June 2020)
  19. #9520
    May 2016
    lower west victoria
    30 Post(s)
    Very slick mate ^^^^
