Results 1 to 10 of 10
Thread: Driver door central locking actuator faulty
    Jul 2019
    Marlborough, UK
    Question Driver door central locking actuator faulty
    Maybe someone can help me - i'm going mad!
    I have a problem with drivers door lock. It will lock and unlock fine with the key, and locks fine with the remote. However, I cant unlock the drivers door at all using the remote. The other 3 doors all open fine with the remote.
    I've taken the actuator out (the part that contains the two electric motors), swapped to passenger door, and the actuator works fine on that side. likewise, the passenger one works on the driver door too. Unfortunately i cant keep them that way, as they are side specific. looking at the mechanicals inside the actuator there doesnt appear to be anything wrong. I'm at a loss!
    Any suggestions from you guys as to what to look for next ?
    thanks for any suggestions.
    476 Post(s)
    Find what pins on the actuator motor connector make it lock/unlock and run power direct to it and see if it works. Then at atleast you can rule out one more thing to look at.
    84 Post(s)
    I just looked at your profile it is a y61 model.
    Nov 2019
    Perth
    5 Post(s)
    Mine is doing the same.
    I just use the key to lock/unlock particularly in this modern era of car hacking. Each time you hit the button on your remote it sends out a signal that others nearby with the right hardware are able to duplicate and potentially unlock your car. It's a pretty extreme senario but it does happen to thousands of people everyday ... and I'm a bit OCD.
    2008 CRD Auto Wagon
    Jul 2019
    Marlborough, UK
    Sorry mate, yes its a 2005 Y61.
  6. #6
    Jul 2019
    Marlborough, UK
    yeh, ive been doing the same for the last year, but with the lockdown here in UK, ive got some time on my hands......
  7. #7
    Jul 2019
    Marlborough, UK
    thanks - i'll look at tat next.
  8. #8
    334 Post(s)
    They are a known fault. I have just had my car resprayed and when they were putting it back together they called and said there was a problem with it. I knew this so said to swap ot out. It was $300 from nissan and they fitted a new actuator.
  9. #9
    334 Post(s)
    Here is your Future....... Sort it now if you can. Worth replacing it.
    http://www.nissanpatrol.com.au/forum...Door-Wont-Open!!!
  10. #10
    Jul 2019
    Marlborough, UK
    s**t - ok, thanks. guess its off to the stealers....
