Results 1 to 6 of 6
Thread: Window covering
    Dec 2013
    Dordogne, France.
    Window covering
    I am looking for some suggestions on how to cover the rear and back door windows, to keep the sun and nosey eyes out. I have searched but not found any relating thread.
    Thanks in advance.
    Expert Deano2506's Avatar
    Apr 2017
    Hobart,tasmania
    Just get some extremely dark tint on it.
    The rear side and barn door glass is classed as a cargo area,so it can be as dark as you want it and legal too
    Patrol Guru TimE's Avatar
    Canberra
    Look here or just search Solarscreen
    Helps keep the heat down as well, fridge uses less power because it is cooler in the back.
    177 Post(s)
    I used static cling from Autobarn. Cheap and easy to cut , shape and apply. Can hardly see inside from outside but easily the other way around.
    And keeps inside nice and cool. There is two different colours silver and black.
    My only concern after I applied it , that it would peel off as time goes on and it dries ... But
    It's been on the car for more than 2 years now and has not moved.
    Black coreflute sheets from Officeworks. Cheap as. I did my two rear windows and the small barn door. Just remove the window trim, cut to shape, fit on the window and put the trim back on to hold it in place.
  6. #6
    Dec 2013
    Dordogne, France.
    Thanks guy, I knew you'd come up trumps. I'll post some pics when done.
