Page 19 of 19 FirstFirst ... 171819
Results 181 to 187 of 187
Thread: Checking and cleaning MAF sensors
  1. #181
    Quote Originally Posted by Zero Five View Post
    Do i have to Unplugged the battery first before i remove the maf sensor to be cleaned? or i have to remove the maf sensor first and clean it then before putting it back in thats the time i have to unplugged the battery? thanks
    Yes mate all ya have to do is disconnect battery for 30 odd minutes before refitting dry maf..
  2. The Following User Says Thank You to Avo For This Useful Post:
    MB (27th June 2019)
  3. #182
    483 Post(s)
    Very fair question mate, keen to learn also!
    Assuming the ignition is offski should in my nuffy theory be fine, although I did nearly set a 1961 model 6v VW beetle alight installing a fully sic FM/AM radio headset.
    If in doubt, and or welding aboard, disconnect has always been my safe go to for the added extra 2 minutes work !
  4. #183
    483 Post(s)
    Whoops, wrong answer again :-)
  5. #184
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    40 Post(s)
    MAF sensor clean. Am I doing it wrong, always only just unplug elec connector, remove sensor, give it a squirt, let it dry and then just put it back in / connect and go. No problems to my knowledge.
  6. The Following User Says Thank You to Bidja For This Useful Post:
    MB (28th June 2019)
  7. #185
    ECU's are constantly learning and adjusting some engine sensor and operating conditions but it isn't an instantaneous process more a running average sort of deal.
    If you disco the battery for 30 minutes it forces the ECU to immediately start to go thru a relearn process for adjusting individual engine parameters starting from factory or default ECU settings.
    IE the ECU starts from factory trim and ends up at its new trim
    If you don't disco the battery and only unplug and clean the MAF then the ECU maintains its existing trim settings and adjusts its trim starting from that point rather than default.
    IE the ECU starts from the prev trim and ends at its new trim
    FWIW I never bothered forcing a relearn unless I changed the MAF or the MAF was filthy and/or threw codes prior to cleaning as IMHO a relatively clean and functioning MAF won't affect ECU trim all that much after a clean so trim is probably closer to existing than defult.
    Unless you are operating in really grotty environments or getting a lot of Turbo Surge blowing oil film back over the MAF a clean every 30 to 40 thousand K's or so is more than adequate for a normally functioning engine and IMHO the ECU doesn't need a forced relearn
  8. The Following User Says Thank You to the evil twin For This Useful Post:
    Bidja (28th June 2019)
  9. #186
    Jul 2017
    40 Post(s)
    Far bit of road dust around home, guess do maintain air filtration thru life though. Probably has paid off in line with your comment. First 80 thou ks did not go near MAF but have clean every 10 thou ks since (all up 160 thou ks since new veh).
    Then again have had the battery out many times for mods..hahaha
  10. #187
    Sep 2019
    So went to test my maf today and mine does not match any listed here. I have a 6 pin plug with 5 wires. It has nothing in the first pin and then its white, yellow with blue line, yellow with blue line, pink, black. Any ideas on how to test this?? 07 crd auto
