Results 1 to 10 of 11
Thread: Need suggestions on how to clean up the mess I've made.
    Ballarat, Vic
    176 Post(s)
    We went shopping & among all the usual stuff we bought was a block of butter. Carried back to where we are staying in the car fridge. Unloaded the fridge but somehow left the block of butter sitting on some carpet alongside the fridge. 4 hot days later my wife discovers my mistake. The block of butter had well & truly melted inside our Patrol's rear canopy, & the smell was basically that of rancid cheese! What had once been a paper wrapped block, was now flat paper with just a thin covering of 'ghee' on it
    Most of the melted butter has soaked into the carpet, which is glued permanently to the canopy's aluminium floor. As you might expect, just touching the carpet resulted in greasy, stinky hands.
    So far we have spent several days laying multi thicknesses of paper towels onto the carpet & sat heat packs & saucepans of hot water on top of the towels. After 3 days & multiple changes of heat & paper towels the amount of the yellow oil/fat that the towels are absorbing has diminished quite a lot, but nevertheless the carpet still smells like rancid cheese, albeit not quite as badly as it had done. Touching the carpet still feels a bit greasy, but nowhere near as much as it had done.
    The question is 'what next'? Hot water & detergent, followed by more absorbent paper towels with weights on them? Scrubbing with the hot water & detergent? Sprinkling sodium bicarb onto the carpet when dry? Or just leave the whole thing alone & hope the smell dissipates with time? (I don't have much faith in that latter option however).
    Appearance is a non issue, it's removing the smell which is the priority.
    The carpet is a thin short pile marine type carpet. Last resort may be to somehow cut the affected area out, although it is well & truly stuck down.
    Helpful suggestions sought please.
    North brissy
    Hire one of those carpet shampooers from Woolies next time your there and go to town. Other than that you could try steam clean then a wet vac.
    Expert Mickhead's Avatar
    Oct 2019
    My pootrol was putrid when I got it 3 months ago. Even used a hose on the door trims to clean it.
    Search WURTH INDUSTRY CLEANER. Excellent stuff in a spray can. Smells like oranges. This will kill the greasy stuff, even better if you can give it a quick blast with a gerni afterwards,
    Jan 2017
    Thornlie,Perth WA
    8 Post(s)
    Have you tried baking soda on it? Sprinkle a shit load on, rub it in, rinse and repeat.
    Can you heat the affected section of carpet with a hairdryer to try and help release the glue if you want to cut a square out?
    SUCH IS LIFE Maxhead's Avatar
    ACT
    I was going to say steam but Matty beat me to it.
    As above, soda and maybe spray vinegar on it.
    Glen 20 ?
    New truck?
    Sorry mate
    ________________________
    ______ 2017 D-Max _______
  6. #6
    Hardcore jack's Avatar
    Ballarat Area
    25 Post(s)
    Leave it open in the rainforest, the jungle creatures will clean it up for you. Or you can borrow our dog, he’ll eat anything that stinks, including the carpet.
    Sorry Cuppa, couldn’t resist.
    Jack
    2024 Isuzu MUX
  7. #7
    Vanilla will cover the stinks
    Thought to self velcro carpet to alluminium floor
    in case there is "Buttergate 2020" lol
  8. #8
    Advanced Finezy's Avatar
    Geelong - VIC
    3 Post(s)
    You could lay an old towel down or paper towel and iron it... I got dried up crystallized cough mixture out of my passenger seat this way
    2001 GU II ST, 3.0di, Auto, All NADS done, Nissan Snorkel, 50mm Lift, 35's....
  9. #9
    If it is marine carpet then spray the area liberally with windex (glass cleaner) and give it a scrub with a nail brush or short bristle brush to get the windex right into the carpet.
    Mop up with paper towel
    Give the area a rinse with clean water
    Mop up again with paper towel
    Spray with Carpet deodouriser (pet grade if you have it) vanilla, orange oil or what have you.
    Works a treat on the carpet in the boats at work and is fun to watch people gag as they clean up the left overs from their chunder.
  10. #10
    198 Post(s)
    Quote Originally Posted by Finezy View Post
    I agree with this method, have used it to mobilise oil and grease from carpet before, change the scott towel frequently but use just heat, not steam -
