Results 1 to 4 of 4
Thread: y60 Auto to Manual conversion
    Beginner Convert's Avatar
    Dec 2019
    Today I started a manual conversion.
    replacement brake pedal also.
    new rear crank seal, clutch etc.
    Dash out.
    Mission.
    One question though
    Are there any hidden surprises in the wiring of the manual box to the ex Auto truck 1993 td42?
    Dec 2019
    Well that job is done.
    Long story short, take out engine mounts and drop engine 50mm.
    Raise rear of truck, leave front wheels on ground
    access top Bell housing bolts from top of tunnel through the shifter hole.
    Use two trolley jacks.
    Allow 2 days for a man and a lad.
    Remove entire dash and vent duct to fit new Brake pedal assembly.
    Test reverse switch of box before putting box in.
    I also changed crank seal, clutch and release bearing at same time.
    Result is a much better truck
  3. The Following 4 Users Say Thank You to Convert For This Useful Post:
    0-TJ-0 (23rd January 2020), Lawrence (25th January 2020), mudnut (23rd January 2020), Touses (23rd January 2020)
    Mar 2020
    Any pics would be great
    Sent from my CPH1989 using Tapatalk
    Jan 2023
    Any photos on this?
