Page 24 of 106 FirstFirst ... 2223242526 ... LastLast
Results 231 to 240 of 1053
  1. #231
    177 Post(s)
    I was about to hang sh*t on those blade type circuit breakers, but noticed in time that they are manually re-settable.
    I had some auto reset circuit breakers of similar type, but would never consider having them again. I was fault finding, something to do with solar charging IIRC. It was a nightmare, very difficult to track down. In the end it came down to substitution to find where the problem was & it turned out to be the blade type CB, confirmed by opening it up. The design was essentially a dished piece of metal which would 'pop' out when over current heated it sufficiently. Once cooled down it would return to it's default state, reconnecting the power creating a very difficult to track down intermittent fault. In this instance the culprit was poor quality construction. The 'dish' held in place by a rivet through it's centre was loose, creating a poor connection & excess heat.
    Manually re-settable ones are a different ballgame. You can see when they are 'tripped', & they stay tripped until you reset them. For lower amps (15a, maybe 20a & below) they are a great alternative to fuses.
    Higher amp versions would likely suffer the same problem as the higher amp fuse versions - oxidation on the blades resulting in resistance & heat build up without blowing - creating a fire risk.
  2. #232
    Yeah I will not run this fuse in the car buy rather in an empty slot or.my tool box specifically for fault finding .
  3. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Cuppa (11th January 2020)
  4. #233
    Winner this ‘Lazy-MB 2020 Pumpkin Filler’ :-)
  5. The Following 5 Users Say Thank You to MB For This Useful Post:
    Mc4by (11th January 2020), PeeBee (11th January 2020), Plasnart (11th January 2020), Rossco (11th January 2020), Touses (13th January 2020)
  6. #234
    Patrol Freak Mc4by's Avatar
    Oct 2016
    Mandurah W.A.
    7 Post(s)
    Clever idea indeed.
  7. The Following User Says Thank You to Mc4by For This Useful Post:
    MB (11th January 2020)
  8. #235
    177 Post(s)
    Good thinking batman!
  9. The Following 2 Users Say Thank You to Cuppa For This Useful Post:
    MB (11th January 2020), PeeBee (11th January 2020)
  10. #236
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    Don't know if anyone else uses the stuff but I tried some "Tessa" tape today. I've had some sitting in the shed for a while because I ordered it online and it looked useless once I got my mits on it. I've always hated the sticky mess that electrical tape leaves after it gets hot/old.
    I got sick of looking at the mess my head/driving light wires are in(i'll fix it properly 'one day') when I was in there today so decided I'd whack a bit around it and give it a trial run before it all just ends up in the bin.
    The stuff surprised me.
    Good points: It doesn't stretch so you can get a nice tight wrap. You can cut short strips and feed it around existing looms without it sticking to everything/itself. It sticks pretty good(better than you would think before you use it).
    Bad points: I think the ends might peel up over time. It does leave a sticky residue immediately(I had to redo a bit) if you peel it off, although nothing like 12 month old electrical tape after a few heat cycles. Will probably attract dust and dirt and not look as clean as tape after a wash.
    I don't think it'll replace normal tape in the toolbox but if it lasts I think it'll have it's uses. I think it would be ideal doing under dash stuff.
  11. The Following 2 Users Say Thank You to 0-TJ-0 For This Useful Post:
    Cremulator (14th January 2020), MB (13th January 2020)
  12. #237
    Yes that stuff is awesome! I love it. Looks neat as buggery and perfect for covering my butcher sparkie work.
  13. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    0-TJ-0 (13th January 2020), MB (13th January 2020)
  14. #238
    Completely forgot we purchased this hidden ripper many years ago at a farming type expo after a plague of dreaded Mozzies bombarded us!
    We had home trialled many other contraptions including DEET as a spray camping backup to no avail :-(
    Aussie made was lead to believe back then and tonight working a biting treat again on low voltage fan capturing below cage unlike near fire starting zappers that do kill good Bogong Moths
  15. The Following 3 Users Say Thank You to MB For This Useful Post:
    0-TJ-0 (24th February 2020), Rossco (23rd February 2020), rusty_nail (23rd February 2020)
  16. #239
    Jan 2017
    South Australia
    11 Post(s)
    Saw these today and thought might be worth having one in the toolbox for $9
    Probably nothing new but I've never seen them. May find a use for it.
  17. The Following 2 Users Say Thank You to 0-TJ-0 For This Useful Post:
    Cremulator (15th March 2020), MB (15th March 2020)
  18. #240
    Well that looks awesome!!! Keen to see the size of these things!!!!
  19. The Following 3 Users Say Thank You to MudRunnerTD For This Useful Post:
    0-TJ-0 (18th March 2020), MB (25th April 2020), PeeBee (18th March 2020)
