Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 52
Thread: Meet da Mav!
  1. #31
    Nov 2019
    Melbz
    All done from that end.
    RHS is nearly done and then bleed the brakes before it’s finally on the ground.
  2. #32
    Nov 2019
    Melbz
    Finally on terrafirma
  3. The Following 3 Users Say Thank You to Count Grantleyish For This Useful Post:
    Cremulator (30th December 2019), MB TD42 (15th January 2020), PeeBee (29th December 2019)
  4. #33
    Nov 2019
    Melbz
    Grill is in. Still to tidy up the wiring for RHS indicator before it’s fixed and bull bar being plonked on.
  5. #34
    Nov 2019
    Melbz
    It’s starting to look like a car now.
  6. The Following 3 Users Say Thank You to Count Grantleyish For This Useful Post:
    Cremulator (30th December 2019), MB (30th December 2019), MB TD42 (15th January 2020)
  7. #35
    Nov 2019
    Melbz
    Got to work on the Mav today, finally sourced non twisty steering wheel and took it out and then put the non twisty wheel in, replaced the negative earth cable, now working on RHS rear door as it’s playing up.
    Now to do flares, windscreen and wipers.
  8. The Following User Says Thank You to Count Grantleyish For This Useful Post:
    MB (5th January 2020)
  9. #36
    Nov 2019
    Melbz
    The door is fixed! As it turns out the plastic bit where handle goes in the lock mechanism were loose and mate has fixed it.
    While measuring for flares and I’d discovered that LHS sticks out more than RHS meaning it has lift of some sort.
  10. The Following User Says Thank You to Count Grantleyish For This Useful Post:
  11. #37
    Nov 2019
    Melbz
    Quote Originally Posted by Count Grantleyish View Post
    After some googling, it may not be the case, either way I need to sort it out because 20/25mm variation from LHS to RHS.
  12. The Following User Says Thank You to Count Grantleyish For This Useful Post:
  13. #38
    Nov 2019
    Melbz
    No updates apart from bought a set of GU4 springs for $10 and see if axles are in-line with the chassis.
    Don’t think I’ll get to spanner for a while, my back is now playing up and I’m at doctors office as I write this - fun times ahead!
  14. The Following User Says Thank You to Count Grantleyish For This Useful Post:
    MB (26th January 2020)
  15. #39
    Jun 2018
    25 Post(s)
    Argh, good luck. Back pain is never fun when you can't stand up straight.
    While you're at the doctor's, get them to check if you have a 20/25mm variation from LHS to RHS.
  16. The Following 2 Users Say Thank You to Cremulator For This Useful Post:
    Count Grantleyish (15th January 2020), MB (26th January 2020)
  17. #40
    Nov 2019
    Melbz
    Yep, not so nice... and maybe I should!
  18. The Following 2 Users Say Thank You to Count Grantleyish For This Useful Post:
    Cremulator (15th January 2020), MB (26th January 2020)
