Results 21 to 30 of 32
Thread: ATF in transfer case?
  1. #21
    483 Post(s)
    Just dusted off the old Gregory’s Y61/GU 1998-2014 manual.
    Chapter 7 Part A
    Manual transmissions
    Model FS5R50B
    TB45E, TB48DE, ZD30DDTi, TD42
    SAE 75W-90 GL4
    3.5 Litres
    Model FS5R30A
    RD28ETi
    SAE 80W-90 GL4
    5.1 Litres
    Chapter 7 Part B
    Automatic transmission
    Model RE4R03A = Four-speed
    Nissan Matic D or Dexron III
    Approximately 12.0 Litres
    Model RE5R05A = Five speed
    Nissan Matic J
    Approximately 11.0 Litres
    Chapter 7 Part C
    Transfer case
    Model TX12A
    Fitted to all models
    Nissan Matic C or SAE 75W-90 GL4
    1.9 Litres
    Certainly is weird that they specify both a tranny “or” gear fluid with no other explanation throughout Part C.
    Will have to scour Part B I guess?
    PeeBee (27th December 2019)
  3. #22
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    John, that's interesting for sure. I would not have thought the oil properties for an ATF would be suitable for a gear loading application - obviously they are especially if you have been doing this for close to 13 yrs! Learnt something new today.
    The planetary gears in the auto trans take a fair bit of loading. I'm rebuilding an RE4 auto at the moment that has done 326k kms and, although the clutches are well worn, the planetary gears look perfect.
    John
  4. The Following User Says Thank You to jff45 For This Useful Post:
  5. #23
    84 Post(s)
    A more experienced and wiser member explained it all a very long time ago. Early GQs ran gearbox oil in their Transfer cases.(Hence the listing calling for Gear Box Oil) . Mark, please check the year of publication. It was found that the shaft running through the Transfer case could cause the chain to rotate, making the front drive train turn. It was more prominent in colder weather. My '94 runs Auto Trans Fluid, but has manual hubs.
    I would expect auto hubs to try and engage if the heavier gearbox oil was used.
  6. The Following 2 Users Say Thank You to mudnut For This Useful Post:
    MB (27th December 2019), PeeBee (27th December 2019)
  7. #24
    Nov 2019
    Perth
    5 Post(s)
    Thanks for your replies. I did a bit of reading here too and it sounds satisfactory.
    https://www.patrol4x4.com/threads/tr...ase-oil.30931/
    2008 CRD Auto Wagon
  8. The Following 2 Users Say Thank You to pollenface For This Useful Post:
  9. #25
    483 Post(s)
    Sounds fair thanks Craig mate, will dump the gear oil and take the safer second option for her auto hubs
  10. #26
    84 Post(s)
    This is from the downloaded GQ manual:
  11. The Following 2 Users Say Thank You to mudnut For This Useful Post:
    MB (28th December 2019), PeeBee (27th December 2019)
  12. #27
    84 Post(s)
    And this is the GU manual.
  13. The Following 3 Users Say Thank You to mudnut For This Useful Post:
    MB (28th December 2019), PeeBee (27th December 2019), rusty_nail (27th December 2019)
  14. #28
    sunshinecoast
    3 Post(s)
    yes . it's a viscosity thing , the friction of the free spinning gear in the TC spins the front driveshaft /diff and engages front hubs . people hear noises comeing from hubs and complains to mr nissan . mr nissan says use lower viscosity atf and viola!! no more warranty complaints . atf being a very good quality oil does the job just fine , just a bit more expencive
  15. The Following 2 Users Say Thank You to nipagu7 For This Useful Post:
  16. #29
    84 Post(s)
    Well this is going to be a bit of an experiment: I found out today the mechanic who changed out the gearbox and transfer case used gear oil in the transfer case.
    I drained and filled the case with the recommended ATF. It will be interesting to see if the noises will die down, the gear shift when cold is easier or the oil seals will start leaking.
  17. #30
    477 Post(s)
    Do you run auto hubs on your GQ Craig? Cold gear shifting won't change one bit when switching transfer case oils. Or am I reading this wrong?
